Go to Post Our thanks does not have to come from their lips. It comes from the finished product that walks across the stage, gets their diploma and moves on to bigger and better things. - Koko Ed [more]
Unread 01-02-2007, 18:51
neo's Avatar
neo neo is offline
whoa.
AKA: Dan Murrow
FRC #0585 (THS CyberPenguin Robotics)
neo has a spectacular aura aboutneo has a spectacular aura about
Light powering - voltages?
First of all, we are wondering how other teams are powering their light boxes. We've tried computer PSUs, but either there isnt enough voltage or enough amperage (we have 3 lights. .7A x 12). We've tried running straight from a battery, but the voltage diminishes and the camera notices. I rigged up a second plug to one of last year's batteries and plugged it into a charger while the battery powered the lights. This just tops off the battery at ~13.6v.
Second question is, does anyone know what FIRST is powering their lights with? If they are using a 120v to 12v converter and letting those light have a constant 12v, would it make a difference if other teams are running their lights at 13-14v?
thanks.
Unread 01-02-2007, 19:02
Robert Cawthon's Avatar
Robert Cawthon Robert Cawthon is offline
Robert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to behold
Re: Light powering - voltages?
I am using a battery from last year and it seems to be doing ok. I have not noticed the camera complaining of the loss of light.
Unread 01-02-2007, 19:47
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
If your talking about the Green Lights that FIRST uses I have been using a 12v battery to power the lights. Chances are FIRST will use a 12v power supply to power the green lights.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 01-02-2007, 21:14
Daniel367's Avatar
Daniel367 Daniel367 is offline
Dan
AKA: Daniel Rahamim
FRC #0008 (Paly Robotics)
Daniel367 is on a distinguished road
Send a message via AIM to Daniel367
if you find out what power supply they are using let us know. when I tested how much current the boxes were pulling (i was using two fans to cool it though i think the design only calls for one) i got a reading of 1.3 A at 12v DC. for just one box with 8 lights.
Unread 01-02-2007, 21:16
mtaman02's Avatar
Did you check the Field Manuals on the Green Light Assy. They may have listed power source and such. As a matter of fact I'll go look that up now. Ok I just remembered that the Green Light is controlled by the arena controller and is powered from the same area as well so it is safe to say it has to be a 12vdc power source within the arena controller. The arena controller gets 120vac and then breaks it up for the competition controller, vision target, sensors and whatever the game is designed around. Boy does it pay off to be part of a field assy & dis-assy crew. Kinda remembered that from 2006. But then again the Target was above the station so maybe instead of having the wire come up through the rug they'll have a remote power source in the middle of the field. We'll I can't find anything in the field manuals as far as how it will be wired except that if a robot intereacts with the wiring the robot will be disabled / penalized or something like that. Which leads me to believe that the wiring may travel under the the rug and up the center of the rack and then terminate to each of the Targets.
Volunteer Resume:
Unread 01-02-2007, 21:41
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
The power supply to any computer speaker set with a sub woofer (of the right voltage) should have exactly enough kick for you. They range anywhere from 700ma to < 1.5a depending on the size of your sub... So they will definately be able to power the cathodes. You don't even need to cut wires if you don't want to... using a little electrical tape I was able to hook the load (in my case not the KOP lights) up to the existing power jack on the cord with no risk of fire/failure.
As a side note: I was actually doing this to power a car amplifier/stereo system with 12" subs in my room. I used the power supply from a $40 pair of computer speakers to hook directly into the amp power in, and since those subs drew a heck-of-a-lot more current than the cathodes, I don't foresee any problem at all. I don't know if there is some difference which I am overlooking, but there shouldn't be.
Last edited by Al Skierkiewicz : 03-02-2007 at 22:11. Reason: note about the right voltage is needed.
Unread 01-02-2007, 21:51
neo's Avatar
neo neo is offline
whoa.
AKA: Dan Murrow
I tore apart one of the PSUs i spoke of before. there were some potentiometers inside labeled VR1 and VR2. VR2 happened to be the one that regulates the 12v output. got it up to 11.8v with the lights on, 11.7v without them on (weird). but it is close enough to 12v and is a constant voltage.
Unread 02-02-2007, 20:39
neo's Avatar
neo neo is offline
whoa.
AKA: Dan Murrow
got the question answered.
http://forums.usfirst.org/showthread.php?t=3289
a mentor tested a few of his power supplies and got one that was constant 12v 15a. with the lights on it drops .05v.
Green light same color as overhead light Ethulin Programming 13 02-08-2007 15:24
Multiple Light Tracking with Distinct Light Boxes MaHaGoN Programming 30 19-02-2007 10:46
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
CMUCam and low voltages Ryan M. Electrical 19 22-01-2006 08:54
Battery Voltages in Dashboard Ian W. Programming 10 07-03-2004 16:50
