Go to Post It goes back to what Dave said last year--you can be legal and graciously professional, but still dumb. Play smart. - Billfred [more]
Unread 01-02-2007, 20:55
team877's Avatar
team877 team877 is offline
FRC #0877 (Cub Robotics)
team877 is an unknown quantity at this point
making a trigger a toggle
how can i set my relay on my controller to just turn a pwm port to on or off so that i dont have to hold down the trigger?
Unread 01-02-2007, 21:04
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
Re: making a trigger a toggle
Hi, I'll post below what I'm using right now... As a sidenote, I have two variables you'll need. One is name "port1_trigger" and the other "Lift."
void Lift_Control ( void )
      if ( port1_trigger == 1 ) // If the trigger was pressed last.
            Last_Button_Pressed = 1 ; // Then the trigger was pressed last.
      if ( port1_thumb == 1 )
      { // If the thumb button was pressed last.
            Last_Button_Pressed = 2 ; // Then the thumb button was pressed last.
      if ( Last_Button_Pressed == 1 ) // If the last button pressed was the trigger, then....
            Lift = 1  ; // Lift the platform!
      else
            Lift = 0 ; // Don't lift the platform.
      SetRelay ( 1 , Lift , -1 ) ; // The spike relay will have the value of the variable "Lift."
I hope that helps
-Nathan
Unread 01-02-2007, 22:44
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
static char p1_trig_state = 1;
static unsigned char p1_trig_pressed = 0;
if(p1_sw_trig && !p1_trig_pressed) {
    p1_trig_state *= -1;
    p1_trig_pressed = 1;
else if(!p1_sw_trig)
if(p1_trig_state==1)
    pwm01 = 255;
else
    pwm01 = 127;
with any toggle code, if your output switches state rapidly a few times after your input is pressed, you might need to add a little delay to debounce the input
Unread 02-02-2007, 13:26
Racer26 Racer26 is offline
well, if you're trying to turn a motor/solenoid/whatever else on/off only, without variable speed, i would use a spike. the code is simple.
static char trigold = 0; // Define this with global scope
if(p1_sw_trig == 1 && trigold == 0){
       relay1_fwd = !relay1_fwd;
trigold = p1_sw_trig;
That should toggle relay1's fwd direction each time there is a 0->1 transition on the port 1 trigger.
360 Button, trigger, and joy stick? GMAdan Programming 4 16-01-2007 19:07
toggle switch Windward Programming 31 27-01-2006 22:38
Pneumatics on a toggle switch Idaman323 Programming 3 15-02-2005 18:42
Ball Chute Trigger pludodog Technical Discussion 1 12-01-2004 10:26
Toggle? f22flyboy Programming 5 03-11-2002 08:03
