Go to Post Spelling mistakes make me sad...Almost as sad as not being able to go to Atlanta this year.. Almost. - Elgin Clock [more]
Unread 01-02-2007, 21:26
Jon Anderson's Avatar
Jon Anderson Jon Anderson is offline
Jon Anderson is a glorious beacon of lightJon Anderson is a glorious beacon of lightJon Anderson is a glorious beacon of lightJon Anderson is a glorious beacon of lightJon Anderson is a glorious beacon of light
Send a message via AIM to Jon Anderson
Re: using servos with camera
Originally Posted by team877 View Post
and also when the robot gets to the light how can you make the robot stop
The way that we're stopping our robot in autonomous mode is having the our motors stop once the tilt servo on our camera reads a certain amount, in our case it's currently at 200. Your code look roughly something like the following:
if (TILT_SERVO > 190)
   LEFT_DRIVE = 127;
   RIGHT_DRIVE = 127;
TILT_SERVO being which ever output you choose (it's pwm slot 2 for the default Kevin code), and LEFT_DRIVE, RIGHT_DRIVE being their own respective pwms.
Camera without servos kiettyyyy Programming 17 10-04-2006 21:45
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
servos and the camera incognito_NICK Programming 5 09-02-2005 00:00
Servos for the camera MV_Hirsch Programming 4 24-01-2005 16:35
using older servos pryoplasm Kit & Additional Hardware 4 24-01-2004 20:22
