Go to Post FIRST has set me on a completely different path in life. And I'm all the better for it. - Vincent Chan [more]
Unread 31-01-2007, 20:34
CMB CMB is offline
FRC #0135
CMB is an unknown quantity at this point
About that bumper...
Does anyone know if we can have a bumber that is one continuous piece around the robot? It would look kinda like an inner tube... work or not?
Unread 31-01-2007, 20:43
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
Re: About that bumper...
you can have whatever you want if it is within the starting robot dimensions initially, included in the robot weight, and would function within the bumper zone ( 2.5" - 8.5" from the floor)
However, if you wish to take advantage of the extra 15 lbs allowed for the bumpers outlined in the kit, then they MUST be made EXACTLY as outlined in rule <R37>
-Jeff
Unread 31-01-2007, 20:53
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
As long as the plywood backing of the bumpers does not extend past the 38x28 starting envelope of the robot, you can have an all-emcompassing bumper.
Unread 01-02-2007, 21:29
Check <R37>--you're off by an inch or so.
Originally Posted by <R37>, Section 8, 2007 Manual
  • In the STARTING CONFIGURATION, STANDARD BUMPERS may extend outside the horizontal dimensions for the ROBOT (as specified in Rule <R07>) by up to a maximum of 3- 1/2 inches per side. Nothing other than pool noodles and cloth can extend more than 1 inch beyond the ROBOT boundaries.
  • Hard bumper parts MUST NOT extend into the corners.
It's 1" outside the robot for the plywood, up to 3.5" for everything else. No plywood in the corners.
Custom bumpers are another story.
Unread 01-02-2007, 21:32
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
Sorry, my original post was unclear. I meant no plywood around the corners.
My apologies.
Unread 03-02-2007, 22:03
swiftaaronw2 swiftaaronw2 is offline
swiftaaronw2
AKA: Aaron
FRC #1894 (the elite)
swiftaaronw2 is an unknown quantity at this point
What parts would I need to build a standard bumper.
Unread 04-02-2007, 07:02
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
The exact parts needed and the exact allowable location to mount them, is shown in Section 8 <R37> of the manual where there are even pictures shown.
If you have not made or used bumpers before, I strongly encourage you to look the pictures over and get the materials listed. It's pretty much all there except where and how to interface them to your specific robot.
Question about programing the bumper sensors itsme Programming 9 10-12-2006 18:03
What is special about your HS, or School that you go to D.J. Fluck Chit-Chat 46 11-05-2005 16:39
Just about that time, eh? archiver 2001 1 23-06-2002 22:18
So how about that 190 machine? Greg Perkins Championship Event 2 30-04-2002 22:26
