Go to Post If you spend the money on a new stadium, you might make a profit. If you spend the money on upgrading school lab facilities, you might inspire someone to make a vaccine for HIV. - nathanww [more]
Unread 01-02-2007, 22:33
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Re: Team Update #5 Posted
The answer has been posted http://forums.usfirst.org/showthread.php?t=3276
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 01-02-2007, 22:41
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Originally Posted by GDC View Post
Unmodified Parker-Hannifan and/or Bimba cylinders that are sourced from prior-year FRC Kit Of Parts, and which are one of the sizes listed on the 2007 Pneumatic Components Order Form, and which are identical in size, shape and function to any of the specific part number combinations listed on the 2007 Pneumatic Components Order Form, and which are rated for at least 125 psi, may be used on a 2007 FRC robot. The relevant rules (<R28>, <R48>, <R105> and <R106>) are satisfied. If the cylinder has been modified, it can not be used. If the cylinder is from other than Parker-Hannifan or Bimba, it can not be used. If the cylinder is of a diameter/stroke combination that is not listed on the 2007 Pneumatic Components Order Form, it can not be used. If the cylinder is not the same as one of the Bimba part numbers listed on the 2007 Pneumatic Components Order Form (e.g. it has a different mounting configuration, different piston rod configuration, different sensor integration, etc.), it can not be used. If the cylinder is rated for less than 125 psi, it can not be used.
So you can use one of the old Parker-Hannifan cylinders, as long as it is identical in function to one of the cylinders listed on the current Bimba order form.
OK.
Thank you GDC.
Unread 02-02-2007, 01:26
Umm Errr...
I miss the old manuals. They were better written and overall more consistent.
1139 Alumni
Unread 02-02-2007, 01:49
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
OK, so now it is completely unambiguous. The rules make it clear that Parker cylinders from prior KOPs are permitted (as long as they are of legal sizes, etc.) and FIRST has made it clear that their intent was for Parker cylinders to be legal. The manual and the intent are consistent. Q.E.D. So can we just get over this inane lawyering of the rules and get back to building robots?
Unread 02-02-2007, 09:11
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
Uh, so anyone need 2" bore 12" throw pistons? How about 1.5" bore 8" throw?
Now we've got PLENTY of extras!
-Mr. Van
Coach, 599
RoboDox
Team Update #3 Posted Katie Reynolds Rules/Strategy 26 21-01-2007 19:41
Team Update #2 is Posted geo General Forum 1 16-01-2004 10:56
Team Update 8 Posted! Harrison General Forum 1 30-01-2003 08:08
Team update #6 posted Joe Ross General Forum 6 22-01-2003 10:14
