Go to Post It’s impossible to know who’s life you will change forever. Don’t miss an opportunity. I’m an optimist. Have a great season. This is the year. - Rich Kressly [more]
Unread 01-02-2007, 23:15
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
Anyone else have this?
Nothing is worse than taking time to design a mount, fabricating it, getting it ready to put on your banebot 36mm gearbox just to find out that the thing doesn't even fit properly. First thing that comes to mind is that you screwed up...well not this time...the gearbox has 8 mounting holes, 2 on each side of the gearbox, 4 of them different from the other 4. Turns out the distance between the lower two holes (let's call them lower if looking straight at the gearbox) is different from the upper ones. It is noticeable with the human eye. A bit sad. Any one else have this? look carefully.
Unread 02-02-2007, 00:11
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Anyone else have this?
Four of the mounting holes are for mounting the Banebots encoder to the gearbox (two for the encoder board, and two for the cover), and the other four are presumably for mounting the gearbox to a plate or something. Looks like you designed around the wrong set of holes. Bummer, dude.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 02-02-2007, 00:22
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
designed around the larger ones, didnt find the right thread for it, tried the smaller ones, they are the ones differently spaced...so are you saying everyone's is like that?
Unread 02-02-2007, 00:45
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
As far as I know, yes. I didn't inspect the holes on our gearbox. However, we just installed our encoder today, and I noticed there was a slight difference in the spacing of the holes on the two different parts of the encoder assembly. Since it all fit together very nicely, I can only assume that the holes on the gearbox must also have been spaced differently.
_
Unread 02-02-2007, 09:26
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
except on the inventor file from firstcadlibrary they are spaced evenly. I think it's pointless making them differ in spacing so little yet enough to limit what you can do with it...I'm sure the encoder has enough space for equadrilled holes
Anyone else have any piercings or tattoos? Josh Hambright Chit-Chat 25 11-01-2008 23:54
did anyone else have this problem? NuclearPeanut FIRST Tech Challenge 0 25-04-2005 14:34
Anyone else have school cancelled? ryanspensley Chit-Chat 14 09-04-2003 06:03
Anyone else have trouble flying? authgeek1218 Championship Event 7 07-04-2003 02:35
118's Valkyrie Rides... (anyone else have videos?) Kris Verdeyen Robot Showcase 0 24-02-2002 21:13
