Go to Post Push the envelope a little, but not too much. There's a difference between being on the cutting edge and being on the bleeding edge. - cadandcookies [more]
Unread 01-02-2007, 15:39
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Question Pick-up Device
We have been considering a wedge tipped device to get under the innertubes. However the rules imply no wedges on the robot. Do these include the actual device to get the innertubes or just the sides of the robot.
Unread 01-02-2007, 15:42
Kristian Calhoun's Avatar
Kristian Calhoun Kristian Calhoun is offline
Celebrating 20 years of 25
FRC #0025 (Raider Robotix)
Kristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond repute
Send a message via AIM to Kristian Calhoun
Re: Pick-up Device
I believe that rule <R05> clearly defines the purpose and usage guidelines for wedges, as you mention for picking up the inner tubes:
Originally Posted by <R05>
<R05> "Wedge” ROBOTS are not allowed. ROBOTS must be designed so that interaction with
opposing ROBOTS results in pushing rather than tipping or lifting. Neither offensive nor
defensive wedges are allowed.
All parts of a ROBOT between 0 and 8.5 inches from the
ground (the top of the BUMPER ZONE) that are used to push against or interact with an
opposing ROBOT must be within 10 degrees of vertical. Devices deployed outside the
ROBOT footprint should be designed to avoid wedging. If a mechanism or an appendage
(e.g. a harvester for retrieving GAME PIECES) becomes a wedge that interferes with other
ROBOTS, penalties, disabling, or disqualification can occur depending on the severity of the
infraction.
Raider Robotix: Home | Twitter | Facebook | Instagram
Brunswick Eruption: Home | Twitter | Facebook
Unread 01-02-2007, 23:28
GMKlenklen's Avatar
GMKlenklen GMKlenklen is offline
The "Masonater"
AKA: George Mason Klenklen
FRC #2167 (MASMabots)
GMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to all
Send a message via AIM to GMKlenklen Send a message via MSN to GMKlenklen Send a message via Yahoo to GMKlenklen
Re: Pick-up Device
So IMO, don't deploy your "broom and dustpan" ringer-picker-upper while another robot is driveing by. But I would say that it's pretty easy to design something that would not physically be able to "wedge" a robot in any segnificant way. I don't remember the refs and inspectors being REALLY nit-picky about things, but if you did something that could maybe possibly be bad, but in 98% of circumstances wouldn't ammount to much, then they just tell you to be carefull!
Thank you,
formerGrand Master Klenklen
-of the MASMabots-
Unread 02-02-2007, 02:44
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Re: Pick-up Device
Each inspector is different. It'a all about their interpretation of such vague rules. In my sincerest opinion, I would shy away from anything that could be seen by one ref as a rule breaker.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 02-02-2007, 08:48
Molten's Avatar
AKA: Jason
Re: Pick-up Device
Thanks for the posts. I think we will just have to go with our other design that we have been working on.
Pneumatic device wrenauld Pneumatics 3 24-01-2007 10:28
Suction Device Rob2713g Technical Discussion 16 01-06-2006 17:29
External Output Device magical hands Programming 5 15-03-2006 08:31
Shifting Device JT Academy Technical Discussion 28 05-02-2003 21:29
Like Device sasquatch General Forum 6 31-01-2002 08:51
