Go to Post The engineers and mentors provide the "I" in FIRST and FIRST would be nowhere near where it is today without this exceptional leadership shown by so many of these volunteers. - Chris Fultz [more]
Unread 01-02-2007, 11:38
razer razer is offline
FRC #1690
razer is an unknown quantity at this point
again, problems with the camera
i didnt find in the forum a thread with the same problem:
our camera is searching the green light, and when the camera spot it, the camera stop following the green light, and when we turn the camera / the green light - the camera prints us the last values all the time on the terminal window or sometimnes it just types "searching..." but it is stucked.
when the camera spot the green light, the green and the red leds of the camera are on, and when we hiding the green light from the camera it get stucked.
need help...thanks.
Unread 01-02-2007, 18:30
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: again, problems with the camera
Are you using the default camera code that kevin wrote?
www.kevin.org/frc
Unread 02-02-2007, 06:51
FRC #1690
www.kevin.org/frc
yes, i use his default code.
Unread 02-02-2007, 09:26
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
You mean, it finds the light, but doesn't follow. It finds it, stays in it's position and only once the light is out of range it starts moving for searching mode untill it finds the light again? Kind of sounds like what happened to us before the TTL problem, but we might still have it. Will check next week.
Unread 02-02-2007, 11:50
FRC #1690
i think i found the problem,
i saw that the PWM of the power slides out a bit while the camera is rotating because the camera is ratting a bit while searching the green light, and i try to shake this PWM by myself and i saw that the LEDs were turning off for half a second and then turns on again, so i just tightened the wires...
thanks anyway for trying to help me
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
problems with my truck again. greencactus3 Chit-Chat 12 30-11-2005 17:49
yet again i have more computer problems Timmyd Chit-Chat 22 27-11-2005 16:30
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
Once again offering problems, but no solutions archiver 2000 1 23-06-2002 22:53
