Go to Post But should we "discriminate" based on how long your team has been around? If you think about it, FIRST's goal is to inspire students, right? ...But students on rookie and second-year teams, if anything, are in greater need of being inspired. - LauraN [more]
Unread 01-02-2007, 15:10
joesmomh00haha's Avatar
joesmomh00haha joesmomh00haha is offline
sneeble
AKA: sneeble
FRC #1841 (Crazy Bred)
Team Role: Mascot
joesmomh00haha is infamous around these parts
Exclamation button programming
How do you program the buttons on the 360 controller?
Unread 01-02-2007, 15:17
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
Re: button programming
It should all be in the user manual.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
Unread 01-02-2007, 15:30
sneeble
AKA: sneeble
Team Role: Mascot
Exclamation Re: button programming
we have read it several times and we need to know how to program the controller to use the triggers, rb, lb,a,b,x,y,and the right joystick. We need them to operate some motors through the relay outputs. Our programmers are new to this and we can use the help.
Unread 01-02-2007, 15:38
Andrew Morris's Avatar
Andrew Morris Andrew Morris is offline
Oh hey, it's build season!
FRC #0177 (Bobcat Robotics)
Team Role: Student
Andrew Morris will become famous soon enough
On page 5 of the manual there are tables showing the type of input to the controller you will get in the different modes(eg. trig, top, aux1, wheel). These combined with whatever port you have the controller plugged into give you the names to use for reading them(eg. p1_sw_trig, p1_sw_aux1). Then you can use those to control the relay ports on the RC.
If you want to use all the buttons and the right stick but not the left stick you should use mode 4 on the USB chicklet
2010 Newton Division & Championship Winner w/ 67 & 294
2009 CMP Champion - Newton Division
2008 CMP Champion - Archimedes Division
2007 Newton Division & Championship Winner
Unread 01-02-2007, 15:48
Hieb Hieb is offline
Hieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to behold
First you'll need to figure out which ports the buttons map to. I don't have time for much detail, but I'd probably just write in a quick debug routine with printfs to show in the terminal window which button was being pushed (ex. p1_trig, p1_aux1, etc).
Unread 01-02-2007, 15:53
sneeble
AKA: sneeble
Team Role: Mascot
the mode is good, we are using mode 3 using the left joystick to control the whole robot(which is what we want). the problem we are having is how to program the xbox360 controller to use motors in the robot(our arm consists of at least 8 different motors for different parts of the arm, and we want to know how we would program the controller to use those motors, we already have 4 buttons programmed(a and b are relay 1, x and y are relay 5) to move or turn on the motors but we don't know how to program the rest of the other robots.)
Unread 01-02-2007, 16:35
AdamHeard's Avatar
Lead Mentor
8 different motors for the arm?
You're probably going to need some feedback on there to make that work.
For the Controller, the chiclet manual tells you what it outputs as. Then in your code you have to change a motor based on that.
The simplist version is proportional drive; but that would be rather inneffective for an arm.
This is an example of the motor from port one being powered by a joystick.
pwm01 = p1_x;
Unread 02-02-2007, 08:02
sneeble
AKA: sneeble
Team Role: Mascot
we need to program the buttons to control the motors. we are ok with the joysticks. the motors need to program through the relay outputs.
Unread 07-02-2007, 08:20
sneeble
AKA: sneeble
Team Role: Mascot
to those who told us to read the manual.
Thank you very much, we have not thought of that.
It is not that we need 8 motors.
we only need 4 but they have to go both ways.
:Also: to add more inputs we tried using "wheel" but it keeps going until we press the "wheel" then it will go the right direction until we let go.
Unread 07-02-2007, 19:22
Tureyhall Tureyhall is offline
AKA: Thomas Hall
FRC #0668 (Apes Of Wrath)
Tureyhall will become famous soon enoughTureyhall will become famous soon enough
wheel is analog. You'll have to do something like:
#define p1_sw_wheel ((p1_wheel > 127) ? 1 : 0)
This means that if p1_wheel is greater that 127 (which I'm assuming is when the button is pressed. If not, change it to < ) it'll evaluate to 1, and if it's less than 127 (which I'm assuming is not pressed) it'll evaluate to 0.
/*Nerd Camouflage*/
2005 SVR - 668+1072+840 - Semifinalists.
2006 SVR - 668+1280+1693 - Finalists.
2007 SVR - 668+604+624 - Quarter-finalists, Xerox Creativity Award, two highest scores (290-2, 128-0) at SVR.
2007 Nat's - TBA.
Unread 08-02-2007, 08:24
sneeble
AKA: sneeble
Team Role: Mascot
Talking Re: button programming
good lookin out. that code is workin so thanks alot.
Unread 09-02-2007, 08:21
sneeble
AKA: sneeble
Team Role: Mascot
Question Re: button programming
new obstacle..
is there a way to make the wheel go as a sw on both the x and y
Unread 10-02-2007, 10:36
sneeble
AKA: sneeble
Team Role: Mascot
Lightbulb Re: button programming
this is a reply to move us to top.
programming motors with programming kit BorisTheBlade FIRST Tech Challenge 4 01-11-2005 19:03
Button making Alex Burman Team Organization 7 10-10-2005 21:45
Joystick Button programming Bharat Nain Programming 5 18-02-2005 11:48
Arm Rotation (1 Button Programming!!) Joelster Technical Discussion 1 14-02-2002 13:15
Button Bar Adrian Wong CD Forum Support 8 04-06-2001 20:27
