Go to Post My puppy certainly thanks the many teams that handed out frisbees this year. - VexisDarksteele [more]
Unread 01-02-2007, 18:58
simpsonboy77 simpsonboy77 is offline
AKA: Garrett Dicken
FRC #0041 (RoboWarriors)
simpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond reputesimpsonboy77 has a reputation beyond repute
Autonomous selector
I was wondering if there is a way to read from the OI, before autonomous, a value. We are coding multiple autonomous functions and I need a way to select which one to run. We can't put it on the robot because we have no inputs left. We have 1 completely unused port on the OI if that helps.
Thanks,
Garrett
Team 41
Unread 01-02-2007, 19:00
AdamHeard's Avatar
Lead Mentor
Re: Autonomous selector
When the robot is disabled before autonomous you can read the OI switches. Set a (static) variable from one of those switches, and then you can choose your mode from that in autonomous.
It's pretty similar to reading one off the robot.
Unread 01-02-2007, 19:01
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
It's written by Kevin Watson. We used a slightly modified version of it.
void auton_selector(void)
static char last_sw1;
static char last_sw2;
if(AUTON_UP == 1 && AUTON_UP != last_sw1)
if(auton_select < MAXAUTONROUTINES)
auton_select++;
else
auton_select=99;
if(AUTON_DN == 1 && AUTON_DN != last_sw2 && auton_select > 0)
if (auton_select == 94)
auton_select=MAXAUTONROUTINES;
else
auton_select--;
last_sw1 = AUTON_UP; //oneshot the trigger and top buttons
last_sw2 = AUTON_DN;
User_Mode_Byte = auton_select;
User_Mode_Byte is the user display on the OI. Use that little button to change to it.
AUTON_UP/DOWN are the defines to which a joystick button or something similar.
Unread 01-02-2007, 22:58
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
We put little switches (the ones that go from 0-9) on the robot and hook them up to the dig in. Before each match, we set the autonomous mode by hand.
Unread 01-02-2007, 23:25
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
We used click wheels like that (except our went much higher than 9) last year. We had two, one for starting position, and one for the autonomous "play". It worked really well for us, although we really ended up only using 3 plays of the many we had available.
You'll be seeing something more advanced this year though if all goes to plan
Unread 02-02-2007, 08:32
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
We used a little toggle switch on the robot last year.
if(rc_dig_in01 == 0)
run_blocking_auton()
else
run_shooting_auton()
Unread 02-02-2007, 11:16
Jared Russell's Avatar
Taking a year (mostly) off
Team 41
You used all 18 digital I/O pins?! Holy cow batman.
Unread 02-02-2007, 11:39
6600gt's Avatar
AKA: Lohit
The code that I posted previously, written by Kevin Watson, allows you have have 254 autons, that can be seen in the user display(the number) of the OI! Beats soldering any switches... We have been using this for the last 4 years at all competitions.
Unread 02-02-2007, 15:14
AKA: Garrett Dicken
We used 16 of them, that only leaves 2 open. That can only make 4 combinations, but we need 5.
6600GT thanks for the tip. I'll be doing that this year as the selector. Thank you everyone for your help.
Unread 02-02-2007, 16:19
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Use the trigger and thumb to set the autonomous mode. Pull the trigger and goto the next number. You can have the OI display what mode you have selected.
Unread 02-02-2007, 16:34
woody's Avatar
woody woody is offline
Too much metal for one hand! \m/
FRC #0033 (Killer Bees)
woody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to behold
Do you have any analog inputs left? If so, you should be able to use a 5 position toggle switch with 5 different value resistors as a sort of multiplexor. Just read the analog value and determine auto mode that way.. i think. im no programmer though ; )
"The greatest of all mistakes is to do nothing because you can only do a little; do what you can." - Sir Sidney Smith
Unread 02-02-2007, 16:37
AdamHeard's Avatar
Lead Mentor
We usedd this same technique to make rotary switches for our OI that used one analog input for various purposes and it works fine. The programming part of it is really simple as well.
Unread 02-02-2007, 17:56
sarcasticmadnes sarcasticmadnes is offline
AKA: Christine Chen
FRC #0115 (Monta Vista Robotics Team)
sarcasticmadnes will become famous soon enough
Send a message via AIM to sarcasticmadnes
Our team (MVRT) has a keypad that takes up one whole port. The keypad is coded in assembly and has its own circuit board and the lcd screen is powered by regular AA batteries. The keypad allows us to have 64 different autonomous positions and choose which alliance we are and which position we are in.
Unread 02-02-2007, 18:05
AdamHeard's Avatar
Lead Mentor
Is it legal to use batteries like that?
Unread 02-02-2007, 18:19
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Does anyone have any multiple autonomous code for easy-C?
-Dustin Benedict
Help with Selector Switch Slick Programming 2 16-02-2005 16:09
[OCCRA]: hose clamps on drill transmissions' gear selector? greencactus3 OCCRA Q&A 1 06-10-2004 05:28
Beacon selector switch? How to find/make? Fen Programming 13 12-02-2004 16:31
Team selector switches on ISAAC Lloyd Burns Robotics Education and Curriculum 0 17-12-2002 08:32
Channel Selector David Kelly Technical Discussion 6 03-06-2001 01:15
