Go to Post I feel like watching match videos from 2003 could be considered a form of cruel and unusual punishment. - Cory [more]
Unread 01-02-2007, 15:57
wedellm's Avatar
wedellm wedellm is offline
Teacher/Mentor
FRC #1158 (EagleCorps Robotics)
wedellm is an unknown quantity at this point
gear tooth sensors purchasing
Has anyone found where we can purchase the sensor as well as the board? I have found the sensor, but not the circuit board. If anyone is not using their gear tooth sensors and circuit boards, we would like to buy theirs.
Unread 02-02-2007, 11:20
Jared Russell's Avatar
Taking a year (mostly) off
Re: gear tooth sensors purchasing
That would most likely not be legal. Custom FIRST parts are not COTS, so you are generally limited to what they gave you for a given robot.
I will look for boards, though.
Unread 02-02-2007, 11:48
I can't find any boards from Allegro. However, I did find some other possible substitutes:
http://www.bbautomacao.com/pdfs/Gear...h%20Sensor.pdf
These act in exactly the same way, but don't have the same "zero speed" capabilities, i.e. their outputs might drift below 10 rpm a bit. The plastic one costs $18.
Unread 02-02-2007, 16:28
wedellm's Avatar
Teacher/Mentor
I do not think it would illegal since they sold them through IFI last year.
Unread 02-02-2007, 19:35
From the FIRST manual:
<R28> COTS ITEMS that are generally available may be used on the ROBOT. COTS ITEMS from
ROBOTS entered in previous FIRST competitions or COTS ITEMS that are no longer
commercially available may be used under the following conditions:
° The item must be unmodified, and still in its original condition as delivered from the
VENDOR
° The item must not be a part custom made for the FIRST competition and provided in a
previous FRC Kit Of Parts (e.g. 2006 FRC transmissions, custom-made motor couplers,
custom sensor strips, IFI CMUcam II modules, etc. are not permitted)
° The item must satisfy ALL of the rules associated with materials/parts use for the 2007
FIRST Robotics Competition
Also note that last year's gear-tooth sensors were a different model, and they are no longer available, and therefore not COTS because not all teams can get them.
Unread 07-02-2007, 20:50
roboticsguy1988's Avatar
roboticsguy1988 roboticsguy1988 is offline
Larry Johnston
AKA: Larry Boy
FRC #1501 (Team THRUST)
Team Role: Electrical
roboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud of
Send a message via ICQ to roboticsguy1988 Send a message via AIM to roboticsguy1988 Send a message via MSN to roboticsguy1988 Send a message via Yahoo to roboticsguy1988
So nobody knows where to get the sensor and the board already together? We are looking for the 2005 gear tooth sensor (with the board). Considering it would be off the shelf they should be legal.
Larry Johnston, Team THRUST, Team #1501, Team THRUST webpage
2005 IRI - Imagery and Design Award
2005 - 2006 BMR - Professional Grade Award
2006 BMR - Delphi Driving Tomorrow's Technology Award
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~ RogerR
~Da team that uses all tha rivets, Team #1501~
The FIRST Software Repository ~ Chief Admin
openFIRST ~ Project Supporter (Former editor)
DMOZ.org - FIRST - US Teams Section ~ Chief Editor
Gear tooth sensors - Forward or backward? Tom Line Programming 6 30-01-2007 09:19
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
Gear Tooth Sensors et1337 Electrical 7 28-01-2006 22:48
Source for Additional Gear Tooth Sensors Madison Kit & Additional Hardware 3 18-01-2006 16:57
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
