Go to Post Now that football is over... ARE YOU READY FOR SOME ROBOTS?!?! - KelliV [more]
  #31   Spotlight this post!
Unread 01-02-2007, 19:30
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
Re: Post sneak peaks of your teams AVA entry
Originally Posted by wt200999 View Post
www.fruityproductions.com/rice/environment4.jpg
The material I am using doesnt have raytrace where I could see it? It the mr design and arch texture. I cant find anything on wave size but I am working on that now
how are you makeing this water? this would help me better understand to tell you what to do.
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
  #32   Spotlight this post!
Unread 01-02-2007, 20:08
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Its just a plane with mental ray Arch & Design with the water template. I have the transparncey at .9 but the rest of the settings are default. Before that I had a raytrace water with noise on the plane. This plane has 1 segment.
  #33   Spotlight this post!
Unread 01-02-2007, 20:14
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
Ok, now here is how I would make water.
a plane with lots of segments. and two wave modifiers on it with the gizmos set at a different angle. Then I would create a standard material for it and set the reflective map to raytrace. that way you have more control over the reflections. Also set the diffuse to falloff, and change some of the colors. Also a bump or a diffuse map woulding hurt either.
A.K.A Llama
  #34   Spotlight this post!
Unread 01-02-2007, 20:17
wt200999's Avatar
Texas Instruments
AKA: Will Toth
thanks for the suggestion, Ill try that now. The only thing I dont like about having a lot of segments is the comuter I am working on. Once I get my computer at home running I will be able to work better on it. Ill try what you said now though thanks
  #35   Spotlight this post!
Unread 01-02-2007, 20:27
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
If your computer is lagging because of too many segments. Then hide the objects that you currently arent working on. You can also press O to make rotating your view easier and less laggy.
A.K.A Llama
  #36   Spotlight this post!
Unread 01-02-2007, 21:22
wt200999's Avatar
Texas Instruments
AKA: Will Toth
http://www.fruityproductions.com/rice/environment5.jpg
Ive been playing around a bit...
  #37   Spotlight this post!
Unread 02-02-2007, 11:00
Setsanto's Avatar
Setsanto Setsanto is offline
FRC #1334 (OTHS RobOTics)
Team Role: Animator
Setsanto is a jewel in the roughSetsanto is a jewel in the roughSetsanto is a jewel in the rough
Send a message via MSN to Setsanto
Your most recent one definately looks the best. The reflecion is a bit clearer and stronger than I think it would be in real life. See this pic
It definately looks to me like you should be putting a bit more of a blur on th trees, not just the distortion from the waves
2008 : GTA Regional 7th Seed, Quarters
2008 : Waterloo Regional 4th Seed, Quarters
2007 : GTA Regional 2nd Seed, Quarters
2007 : Waterloo Regional Quarters
  #38   Spotlight this post!
Unread 02-02-2007, 12:42
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
add some tint and blur to the reflections. And less waves.
A.K.A Llama
  #39   Spotlight this post!
Unread 02-02-2007, 14:18
wt200999's Avatar
Texas Instruments
AKA: Will Toth
http://www.fruityproductions.com/rice/environment6.jpg
I have it at about .75 white tint, and blur? Im looking for blur right now, cant seem to find it in my raytrace properties :?
Also its 800x600 to save time, (it will be even smaller for the final render :| )
  #40   Spotlight this post!
Unread 02-02-2007, 15:45
vadyr's Avatar
vadyr vadyr is offline
103 Alumni/Mentor - FIRST Volunteer
AKA: Bobby
no team (Cybersonics (Mentor))
vadyr is a jewel in the roughvadyr is a jewel in the roughvadyr is a jewel in the rough
Send a message via AIM to vadyr
http://www.putfile.com/pic.php?img=4666851
check that out. i tried to be tricky and not give it away! good luck all!
www.cybersonics.org
  #41   Spotlight this post!
Unread 02-02-2007, 15:58
Setsanto's Avatar
Team Role: Animator
You definately didn't
  #42   Spotlight this post!
Unread 02-02-2007, 17:21
3dfernando's Avatar
3dfernando 3dfernando is offline
Pixel Transformer
AKA: Old Skull
FRC #2026 (Senai-RS)
Team Role: Animator
3dfernando will become famous soon enough3dfernando will become famous soon enough
Bwahahahahhahaha I will steal your idea!
=p =p
  #43   Spotlight this post!
Unread 02-02-2007, 20:17
Mazin Mazin is offline
FRC #1720
Mazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to all
Send a message via AIM to Mazin
Originally Posted by BuddyB309 View Post
mental ray with final gather, I then just plopped a sky light in the scene. (if you dont know what I mean look the terms up in the users reference by hitting F1 in 3ds max)
In other news, Buddy nearly melted his render farm.
I got a shiny new dual-core laptop. I used raytraced shadows, GI, final gather, raytraced reflections/refractions, HDRI environment, motion blur, 3D grass, glow, architectural materials, area raytraced shadows, AND supersampling all while maintaining 20sec/frame render times.
  #44   Spotlight this post!
Unread 02-02-2007, 20:53
Aldabe's Avatar
Aldabe Aldabe is offline
It's a long way to the top
AKA: Eduardo de Souza Aldabe
FRC #0383 (Brazilian Machine)
Aldabe is on a distinguished road
Send a message via MSN to Aldabe
Cool Re: Post sneak peaks of your teams AVA entry
KY SurfaceBlur free plugin !!
official website: http://lastjedioutpost.ru/Plug-ins.htm
download link on a brazilian 3ds max web site:
http://www.tresd1.com.br/plugins.php?t=12918&&start=15
Eduardo Aldabe
Team #383
  #45   Spotlight this post!
Unread 03-02-2007, 14:18
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
Good lord! I have to see a frame of your entry. The animation better be really well done, most people who done use 3ds max dont notice all the reflections and special effects you put in. But they always notice if you have poor animation. I cant wait to see how it turns out.
A.K.A Llama
Where is your team submitting your Regional Chairman's Award entry? rurouni_MOE Chairman's Award 38 11-03-2007 23:28
Can a Rookie entry win the AVA for reigional. BuddyB309 3D Animation and Competition 1 11-02-2006 20:37
Post Your Team Number If your Going to Hartford Competition. DanTheRobotMan Scouting 2 13-01-2006 08:44
Entry Fee Increase---hurting teams Tonya Scott 476 General Forum 50 21-10-2004 08:30
Rookie teams post numbers here! Older teams look for teams to mentor here! Erodge General Forum 1 07-10-2002 13:40
