Go to Post Don't put sprockets in an empty pizza box and then throw it into the garbage. Something we learned from experience. - Herodotus [more]
Unread 02-02-2007, 14:43
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
AM FP Gearbox...feedback?
Last night we had our robot together, nearly 100%. However, the dual 64:1 FP 42mm gearboxes didn't have quite enough torque to lift our manipulator, it's pushing about 30lbs. This is without the claw and additional chain so lets say a safe 40lbs max (this is before shedding weight - we might be replacing the 80/20 1515 for 1515 lite). The 256:1 gearboxes are sold out, and wont be back for this FIRST season.
So this brings me to the AM FP Planetary gearbox. I did some searching but I was wondering if anbody had some feedback concerning my application. Also if someone could recommend another motor, or idea that would great, we are sort of stuck right now.
Thanks
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 02-02-2007, 14:54
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Re: AM FP Gearbox...feedback?
Hi,
That sounds like a pretty heavy arm...depending on the length you are going to have to do ALOT of reduction to get the FP motor into acceptable range. I hope that you have 2 FP motors available to use.
The AM planetary is probably a good start, I have never used it but I think it is supposed to reduce the FP to about the same free RPM as a small CIM (approx 5500 RPM).
One area you might consider is already attached to the motor: the plastic FP gearbox. Consider these possible advantages: They are free, very light and reasonably simple to interface with and mount. Another "advantage" that many dont consider when doing an arm application is that they are pretty inefficient...What you say, how is that an advantage? They are hard to backdrive. If you have 2 of them on your arm the amount of force required to backdrive might be more than the torque on your arm joint from the weight of your arm. This is a huge advantage because your arm can then hold position without applying power to the motors and sparing you from smelling a stalled FP burning up. If you gear your arm right they will always be at high RPM when moving and not need any power to hold position (although with a 30-40 pound arm that may not be the case).
Just something you may want to consider. Best of luck!
RAZ
AdamHeard's Avatar
Lead Mentor
Well, the AndyMark gearboxes only have a 3.67: 1 reduction, So those won't work.
The KOP fisherprice gearboxes have a 124:1 reduction.
Also, you say 40 lbs but we need more information to do calculations. Is it lifted straight, is it a lever arm?
Is the shaft of the BB directly driving the arm, or is chain? If there is chain, you can easily add more reduction in the sprockets.
Unread 02-02-2007, 14:58
Mechanical/Driver
It's a forklift. It's going to move by a chain system, with a sprocket mounted on the shaft and also directly overhead. We're bolting the chain directly to the forklift, so when the motor turns, the forklift goes up. I was thinking about reduction, but the torque needs to be transferred directly to the chain "pulling power", not the sprocket on the other end. Also the chain needs to be somewhat straight, so the two sprockets need to be about the same size.
I was thinking about reducing the gearbox directly by using some gears or something...like a gear mounted on the output shaft of the 64:1 gearbox, turning a larger gear mounted directly to a sprocket, which in turn transfers the torque to the right place.
Unread 02-02-2007, 15:02
AdamHeard's Avatar
Lead Mentor
How many teeth are on the drive sprocket?
If you have 20 or so, you can probably get all the additional reduction by going to a smaller sprocket.
Unread 02-02-2007, 15:05
Mechanical/Driver
Originally Posted by Rob View Post
Hi,
RAZ
We are using two to get the most torque possible.
I was considering re-using our monster 2005 FP gearbox with worm gears, that don't backdrive...is this legal? It was custom built...
Unread 02-02-2007, 15:06
Mechanical/Driver
We are using 10t sprockets on either end, for now.
Unread 02-02-2007, 15:09
AdamHeard's Avatar
Lead Mentor
Okay, so you can't reduce the sprocket size any more. You will need a gearbox with higher reduction; I would suggest the Plastic FP gearboxes.
the gearboxes you have from 2005 are illegal. There is no way around this, you can not use them.
Unread 02-02-2007, 15:10
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
That would not be legal unless you remade all of the custom parts. Off the shelf purchased parts of it such as the worm gears may be legal to use (if they are unmodified).
Good luck,
RAZ
Unread 02-02-2007, 15:15
Mechanical/Driver
Good luck,
RAZ
The whole gearbox was constructed with off the shelf parts, gears, sprockets, and shaft. No custom machining was done. So basically to use these again, we would need to re-cut shaft, re-cut the aluminum casing, and re-tap a few holes?
Unread 02-02-2007, 15:20
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
I am not going to claim to be any kind of expert regarding the rules of using unmodified COTS parts bought in past years because my team is not doing this. If my team was considering it, I would make myself an expert.
If you are thinking of going down this path then VERY CAREFULLY review all of the rules and Q & A responses related to this subject.
I still think that your best bet is to use the plastic FP gearbox.
Best of luck
RAZ
Unread 02-02-2007, 15:28
Mechanical/Driver
Thanks everyone...is there any place to get a new gearbox/motor assembly? We sort of got rid of the plastic gearboxes.....Also the original gears are a bit mangled from getting them off, and the FP motor shaft was grinded down to fit in the Banebots gearbox.
Also, whats the best way to attach a sprocket to the FP gearbox?
Unread 02-02-2007, 15:44
Andrew Blair's Avatar
FRC #0306 (CRT)
As another option, depending on your arm's setup, can you add a counterweight or gas spring to help to offset the load of the arm? If you can design it in, you could potentially reduce the overall average load of the arm by a large amount. Just in my head, I'm imagining close to 30% of the arm's weight. With some clever counterweight/force work, perhaps with constant force springs, you could completely eliminate the weight of arm more or less, and leave your gearboxes to deal only with the acceleration of the arm.
-Sir Francis Bacon
-Albert Einstein
Unread 02-02-2007, 15:46
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Here is a link to a page showing what we have done in the past (and this year):
http://www.joemenassa.com/robotics2005day29.html
You will have to look through and find the images of the FP gearbox and adapter. the shaft goes through the hole in the gearbox and is supported on the backside as well as the front. The metal adapter in the white FP gear is an octagon and has a keyway in it to interface with the shaft. The octagon is just under 1.5" fact to face.
I'm not saying this is the best way, just something that has worked for us.
Best of luck
RAZ
Unread 02-02-2007, 15:58
Mechanical/Driver
Is there anyplace we can buy a whole new motor/gearbox setup?
Mecanum Feedback b_mallerd Technical Discussion 5 03-02-2007 02:19
n.e.r.d. vision feedback MattK General Forum 15 05-07-2006 20:11
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 05-06-2006 11:48
Force Feedback Andrew Blair Control System 67 12-12-2005 18:40
ScoutPro 8.4 feedback chantilly_team Scouting 12 28-05-2005 11:21
