Go to Post They knew that the number of gracious, professional, make-your-grandmother-so-proud-she-will-puke moments of exemplary behavior by the teams would far outshine any minor mistakes or incidents of less-than-perfect decorum. - dlavery [more]
View Poll Results: Wood or Aluminum
Wood 19 14.96%
Aluminum 108 85.04%
Voters: 127. You may not vote on this poll
Unread 31-01-2007, 21:20
Bree Tonte's Avatar
Bree Tonte Bree Tonte is offline
FRC #0234
Bree Tonte is an unknown quantity at this point
Re: Wood vs Aluminum
i would choose aluminum because although it may cost more, it is easier to fix if bent than wood chipping...
Unread 31-01-2007, 21:26
Mike Starke Mike Starke is offline
FRCTop25.com
Mike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond repute
Originally Posted by Zoheb N View Post
that if your robot does get rammed alot during competition you have the ability to beat it back into shape where as if you have it made out of wood it will chip away and become irreplaceable
^Totally agreed.
I have to lean towards trusting welds more than trusting screws or nails, when it comes to either assembling the lower flame, or when it comes to attaching upper frame pieces. Also, if you made it so the two frames would way the same, that would be some awfully thin and unstable wood. 3/4 inch square aluminum is plenty strong for most frames, and is very light.
Unread 01-02-2007, 06:56
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
I have used wood on 10 of the 12 robots built. The right wood works great. Due to the high impact it will take without breaking. Team 61 robot has been know to hit a lot of robots. But the robot frame has never failed. A wood frame works great to start from due to you can place any part on it with out a lot of work. Just pick a spot and put it there. where the Aluminum you need to do a little more work to make it fit.
Wood and the parts it take to put on different devices are cheap. The hardest thing with wood is knowing how to use it in the best way to get the most from it.
Building FIRST robots since 1995
BVT Robotics
Unread 02-02-2007, 02:17
This is my first year NOT working with wood for a drive base, and I must say I don't really have a favorite.
Wood is, for the most part, easier to work with. With little to no resources you can cook up a pretty solid base in less than a day. Electronics mount up nicely to it, and you can even give it a slick automotive paint job. Beyond that, with the proper reinforcement you can slam the thing into walls all day and not have to worry about it bending or breaking.
Aluminum is a bit lighter, and more customizable. You can get some pretty unique shapes and work motor mounts directly into your parts.
I don't really see a big difference in terms of strength (for the purpose of a drive base) between wood and aluminum. Wood has the tendency to gouge, which isnt all that pretty, but for the most part it holds up quite well.
So, I guess its all a matter of personal preference and experience. YMTC.
Unread 02-02-2007, 11:35
travis travis is offline
FRC #2091
travis is a glorious beacon of lighttravis is a glorious beacon of lighttravis is a glorious beacon of lighttravis is a glorious beacon of lighttravis is a glorious beacon of light
Here are some useful properties of Birch (home depot grade plywood material, aircraft grade is void free with superior propeties at about 3X the cost) and 6061-T6 aluminum (all in KSI):
aluminum wood
tensile load at failure 45 10
modulus of elesticity 10,000 2,000
Here is that same table adjusted for density:
tensile load at failure 16.7 16.7 (ahhh perfection)
modulus of elesticity 3703 3333
Price of a clamp = $5, price of a square wave TIG machine = $1500. Home depot grade wood glue can acheive 80% parent material strength with much less skill then welding, and you don't have to heat treat glue joints for full parent properties. Anyone want to race me to install a new limit switch with 2 wood screws vs tapping holes? How about hand jigsawing 10 linear feet? With a rookie team (3rd in a row for me), 6 weeks, and no money, I got wood on the brain.
Unread 02-02-2007, 11:41
zander_108's Avatar
zander_108 zander_108 is offline
AKA: Zander Guerra
FRC #0108 (Sigmac@t)
zander_108 will become famous soon enoughzander_108 will become famous soon enough
Send a message via ICQ to zander_108 Send a message via AIM to zander_108
Originally Posted by Hachiban VIII View Post
Which is better? What I think you should be asking is "what am I building"
There are plenty of good uses for wood, and if used correctly it can offer comparable strength and durability to aluminum.
Our team needs to make a fairly large 5/8" thick plate this year for our tube grabber. After extensive discussion we determined that Baltic birch plywood (a marine grade plywood) would be perfect for this application. The wooden plate would be lighter then the aluminum and would offer reasonable strength and rigidity.
execpt honey-come aluminum...
Unread 02-02-2007, 12:09
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Nice comparison!
although you can use a $1.50 clamp to hold an aluminum bracket on to an aluminum structural part too, if you design it right....no welding needed.
Unread 02-02-2007, 12:21
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Originally Posted by squirrel View Post
Nice comparison!
Well then you can use a 1 cent woodscrew to hold the wood inplace! Beat that!
Unread 02-02-2007, 15:01
MrForbes's Avatar
AKA: Jim
No need to beat that, I was just trying to make the point that you can build a robot with aluminum with only hand tools, if you really want to. There is no need for a TIG welder.
Unread 02-02-2007, 15:14
run the trap!!!
Team Role: Human Player
My team actually has several peices of honey-comb almunium and I assure you it is far easily bent then wood.
We also have some honey-comb carbon-fiber, but its a real dog to work with...
Given the right grade and the correct tools you can make quality parts out of wood.
-Philip J. Fry
Unread 02-02-2007, 15:43
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
We've used wood on our robots before... It has just been hidden from the public eye.
Unread 02-02-2007, 15:45
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Originally Posted by Pika1579 View Post
I heard what you said about not just saying "it looks cooler", but I do consider that to be a factor as well. Both aluminum and wood can make sucessful robots, but I think that most people think of metal as being stronger than wood. With this in mind, I think that if two robots had the same skills, and the same W-L record, an aluminum bot would be picked for an alliance over a wood bot.
Wood doesn't always look worse though. As Tom posted earlier, it can be painted quite easily.
Plus, some wood bots can look quite slick even without paint
Unread 02-02-2007, 16:32
AdamHeard's Avatar
Lead Mentor
I've worked with honeycomb as well. If the cells are unprotected or the face sheets aren't up to part, the cells can easily damaged, or distorted and bent.
From what I've learned (2 years interning in the satellite part of Northrop Grumman). You want to make the honeycomb and face sheets the right size the first time, and never try to cut or reshape it. But then again, my background is where they make every part custom and remake parts rather than adjust an error in a current one.
One time, I had to scrap a whole bunch of panels and once the face became distorted or bent, they lost all their strength. Sure was a fun day.
Back to Al vs. Wood. There doesn't seem to be a universal right or wrong, it all depends on the application. I tend to prefer Aluminum because my team has been able to beg and borrow resources to deal with it, but if we had less we would probably use wood a lot more.
Unread 02-02-2007, 20:38
waiakea2024's Avatar
waiakea2024 waiakea2024 is offline
ZOMGWTHKTHXBAIBBQ!!!!
FRC #1056 (Kekoa o Haaheo)
waiakea2024 is a jewel in the roughwaiakea2024 is a jewel in the roughwaiakea2024 is a jewel in the rough
aluminum is a lot stronger than wood is. also it doesnt swell when wet. (aluminum comes in handy here in hawaii)
Unread 02-02-2007, 23:29
foote stepped in
AKA: E. Foote
FRC #0868
i can tell you that one of our key parts this year is being made out of wood..... i'll post pictures of it after the season is over.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
Using Wood fredliu168 FIRST Tech Challenge 1 30-10-2006 21:46
pic: Wood as an David Brinza Extra Discussion 4 08-04-2006 19:29
pic: 1346 - Wood is Good dtengineering Robot Showcase 21 14-02-2006 02:15
Realistic Wood Corporat 3D Animation and Competition 6 07-02-2006 19:41
Allowed wood types kmcclary Off-Season Events 4 26-10-2001 01:04
