Go to Post ...six-year-old Libby had dragged her by the hand over to my (M.D./Ph.D) father and said, "Daddy, this is Miss Sally. She's a doctor AND and astronaut. YOU'RE just a doctor." - Libby K [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 02-02-2007, 16:01
Dave_Lu Dave_Lu is offline
AKA: Dave
FRC #1564
Team Role: Electrical
Dave_Lu is an unknown quantity at this point
Send a message via AIM to Dave_Lu Send a message via MSN to Dave_Lu
Sprocket Keys and Kit Gearbox
What type of sprocket keys do we need for our kit gearbox shaft? Are they called woodruff keys? And if so are they Full-Radius Style or Flat-Bottom Style? ED: Is this the right shaft key for our gearbox shaft?
http://www.banebots.com/pc/MOTOR-ACC/MR-M0163-38
Thx in advance from The A.Y. Jaguars
Unread 02-02-2007, 16:24
lancerbotics's Avatar
lancerbotics lancerbotics is offline
FRC #2250 (Lancerbotics)
lancerbotics is an unknown quantity at this point
Re: Sprocket Keys and Kit Gearbox
I believe you can get your sproket keys at home depot or lowes. Just take in you sproket and they should be able to help you find what you need and not have to wait for it to ship.
Unread 02-02-2007, 17:22
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
I believe it's 1/8" key. You can get 36" keystock for about $2 from McMaster, Grainger, etc.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 02-02-2007, 17:24
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
The keys are 1/8" square keys, easily most likely at a Home Depot. However, in a pinch I have found that VEX square drive shafts will also work.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 02-02-2007, 17:41
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
I will warn you that the VEX Square shafts are actually rounded on the corners. This is to allow the shaft to fit into the plastic molded clutch packs.
For a very light duty application, and I mean extremely light, that "keystock" will work. However, for a drivetrain, arm, elbow, wrist, etc... I would NOT recommend the VEX square shaft.
As mentioned above, Home Depot should have 1/8" square stock. Otherwise, you can order from McMaster, Grainger, etc...
Good luck,
BEN
Kit Gearbox Ratio jakep Motors 5 04-08-2006 12:58
Kit GearBox Talha Kit & Additional Hardware 2 10-01-2006 21:30
Vex Robotics Sprocket and Chain Kit Morenoh149 FIRST Tech Challenge 3 08-01-2006 22:39
Kit of Parts - Sprocket Spacers? and Transmission Lubrication? wmurphy Kit & Additional Hardware 10 13-01-2005 01:09
wheel hub kit and sprocket archiver 2001 7 23-06-2002 23:27
