Go to Post Secure your battery well, or it will fly like a fish. - Nate Laverdure [more]
Unread 29-01-2007, 02:56
Mitch's Avatar
Mitch Mitch is offline
FRC #1197 (TorBots)
Mitch is an unknown quantity at this point
Distance to travel once targetted?
Okay, so we have the camera tracking the green light and centering the robot onto it. But can anyone drop some hints on figuring out how far forward to go?
I have read that some people go forward depending on the size of the bounds box returned by the t-data, but what other options are there? How are you implementing this?
Unread 29-01-2007, 03:05
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Distance to travel once targetted?
See this document drawn up by Kevin Watson... it may be very helpful.
http://www.kevin.org/frc/2007_frc_range_calc.pdf
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 29-01-2007, 18:03
Michael DiRamio Michael DiRamio is offline
FRC #1114 (Simbotics)
Michael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond reputeMichael DiRamio has a reputation beyond repute
As you move towards the target the tilt on the camera mount will go up.
You could always drive the robot to where you intend to score from, see what the tilt is, then set up your autonomous to drive forward until the camera mount gets to that tilt angle.
Unread 29-01-2007, 18:17
Mitch's Avatar
FRC #1197 (TorBots)
oh of course... I knew this! Thank you.
Unread 01-02-2007, 12:55
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Is there anyone nice enough to tell me the blob size from the edge of the home zone to the target, while the camera is about 1 meter above the ground(or any other hight given)?
Unread 01-02-2007, 23:21
Rindill Rindill is offline
FRC #1329 (VIPRS)
Rindill is an unknown quantity at this point
You can calculate the distance using Kevin's formula. Then using encoders or gear tooth sensors you can create functions to go the wanted distance.
Unread 02-02-2007, 03:28
AKA: Nir Levanon
Not, that's fine, I know how to do that, but I was wondering if anyone can tell me the light's "box" size from that distance.
Unread 02-02-2007, 07:21
There is no way to compute the blob size in advance. It depends on how far the target light is from the edge of the home zone, at what angle the camera is seeing the target light, how well the camera focus is adjusted, the details of lens and sensor geometry on the camera itself, and the distribution of brightness along the white diffuser panel.
The easiest answer is to put a camera where you want and see what it tells you the blob size is. You'll notice that the size changes based on exactly where the rack is and in which direction it is facing.
Unread 02-02-2007, 09:28
AKA: Nir Levanon
As I persumed(spelled correctly?), we'll have to hang the light at the hight and distance from where we position the robot.
Thanks!
Unread 02-02-2007, 11:54
razer razer is offline
FRC #1690
razer is an unknown quantity at this point
is the range in meters? or something else?
and is the angel in degrees? or rdians? i remember that in the TANGENS function in MATH.H it is in radians... so we have to convert from degrees to radians
Last edited by razer : 02-02-2007 at 12:27. Reason: because i needed to ask another question
Unread 02-02-2007, 17:29
AKA: Nir Levanon
Wasn't there a certain sensor that worked with radii degrees too?
Unread 03-02-2007, 08:24
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
Yes, the tan() function in <math.h> takes the degrees argument in radians, so be sure to perform the conversion as Kevin's software calculates the tilt angle in degrees.
The units for distance will be whatever units you specified the light height and camera height with. In the .pdf document above, the 116 is inches, so be sure you calculate h (the height of your camera off the floor) in inches, and then the result will be in inches.
Good luck,
Robinson
Unread 03-02-2007, 11:02
AKA: Nir Levanon
Could anyone give me the (equation/parameter) to convert degrees to radii?
Unread 03-02-2007, 17:44
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
radians == (degrees*PI)/180
(multiply by 3.1415926... and then divide by 180)
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Unread 04-02-2007, 00:17
AKA: Nir Levanon
Thank you!
calculating distance sur2124 Programming 10 15-03-2006 18:36
IR Distance sensor rodgadashruba Electrical 3 02-02-2006 12:22
Long distance... Ashley Christine Chit-Chat 6 27-04-2005 15:11
Running Once? amateurrobotguy Programming 7 23-02-2005 15:33
