Go to Post If it's good enough for Star Trek, it's good enough for FRC. :) - KarenH [more]
Unread 02-02-2007, 17:47
bobpskier bobpskier is offline
FRC #0159 (Alpine Robotics)
bobpskier is an unknown quantity at this point
Source code for the Easy C Pro library functions?
Is possible to look at the source behind the library functions supplied with Easy C Pro for FIRST? For instance can we download the source to the Arcade drive function to see how it is actually coded?
Thanks,
Bob Potterveld
Unread 02-02-2007, 23:37
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Source code for the Easy C Pro library functions?
I'm sorry but the complete source isn't available. But, most of the functions are pretty strait forward. Brad can also post bits of code if he wants.
Unread 05-02-2007, 10:16
AKA: Brad
#0190 ( Gompei and the Herd)
The 2 motor arcade code looks like this:
void Arcade2(unsigned char movePort, unsigned char moveChannel,
	unsigned char rotatePort, unsigned char rotateChannel,
	unsigned char leftMotor, unsigned char rightMotor,
	unsigned char leftInvert, unsigned char rightInvert)
	int moveValue, rotateValue;
	int leftMotorValue, rightMotorValue;
	moveValue = ((int)GetOIAInput(movePort, moveChannel)) - 127;
	rotateValue = ((int)GetOIAInput(rotatePort, rotateChannel)) - 127;
	rightMotorValue = moveValue + rotateValue;
	leftMotorValue = rotateValue - moveValue;
	if (leftInvert) leftMotorValue = - leftMotorValue;
	if (rightInvert) rightMotorValue = - rightMotorValue;
	SetPWM(leftMotor, pwmLimit(leftMotorValue + 127));
	SetPWM(rightMotor, pwmLimit(rightMotorValue + 127));
If you were interested because of wanting to make some changes, you can simply include your own version of this function in your easyC or WPILib program and it will be used instead of the library routine. That's the nice thing about libraries - your project code takes precedence.
Brad Miller
Robotics Resource Center
Unread 05-02-2007, 21:39
Thanks for the post Brad. We are worried about overdriving our motor and might need to be able to adjust how this function works for some of the extremes during operator control.
Bob Potterveld
Problem with easy c pro and mechanum wheels pbrules15 Programming 9 03-02-2007 20:38
From MPLAB To EASY C PRO 354.FIRST Programming 4 30-01-2007 17:13
FIRST Code Library 114Klutz Programming 17 10-07-2006 15:24
how to convert Easy C code into real code? TheHolyLancer Programming 1 29-01-2006 09:09
Do you write functions for your code? Max Lobovsky Programming 26 11-03-2004 07:04
