Go to Post How easy will it be for a driver to control 5-6 different motions at once? Most drivers only have two hands. - Kevin Sevcik [more]
Unread 02-02-2007, 17:26
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Robot Marketplace...heads up.
Just a warning...
Mid 2nd week we placed two orders, for a sum of $500. We opted to pay by check, and next day aired them our check the next day, with confirmation that it was delievered by friday of the second week. They have only sent out a small part of the order, which was just Deans wet noodle wire...and we got that last tuesday. We still have not recieved the rest of our order (consisted of sprockets, shaft, chain, shaft collar, bearing blocks, etc.). We contacted them numerous times, they do not answer our phone calls or emails. I'm still not sure that our check has been cashed....but I'll ask monday.
DO NOT ORDER FROM HERE.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 02-02-2007, 17:38
deshirider430's Avatar
deshirider430 deshirider430 is offline
AKA: Shan Rammah
FRC #0612 (Chantilly Robotics)
deshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nice
Re: Robot Marketplace...heads up.
from where?
2008 NASA/VCU Chrysler Team Spirit Award
2008 Buckeye KPC&B Entrepreunership
2008 Buckeye Regional Chairman's Award
Unread 02-02-2007, 17:40
Mechanical/Driver
Robot Marketplace....
Unread 02-02-2007, 17:42
i like dirt's Avatar
i like dirt i like dirt is offline
"Dude, I Know this Stuff!"
AKA: Sagar
FRC #1694 (Dr. Phillips Tech)
Team Role: Electrical
i like dirt will become famous soon enoughi like dirt will become famous soon enough
deshirider430 from where?
I think he means http://www.robotmarketplace.com the robot online superstore.
KILLER TOFU!!!!
Unread 02-02-2007, 18:02
Andrew Blair's Avatar
FRC #0306 (CRT)
Copy that. Luckily, our order was a lot less- just some cheap #10 wire, and some Anderson connectors, but it's still bad. Supposedly they shipped our order the 22nd, but it still hasn't came. Our mentor has e-mailed them without response.
I second the recommendation- DO NOT ORDER FROM ROBOTMARKETPLACE.com That is, unless you have some time. (Sorry to bash too hard.)
-Sir Francis Bacon
-Albert Einstein
Unread 02-02-2007, 18:07
dfukuba's Avatar
dfukuba dfukuba is offline
Technical Advisor
AKA: Daniel Fukuba
FRC #0008 (Paly Robotics)
dfukuba is just really nicedfukuba is just really nicedfukuba is just really nicedfukuba is just really nice
Send a message via AIM to dfukuba
I know the owner of this online store, personally, and he does not stock everything he has online. He is a marketplace where other merchants post their products. Most of his stuff he has in stock, but other parts such as gears, sprockets and chain are ordered from other distributer, then sent out to you. The robotmarketplace is a great place to buy robot parts. Just keep in mind that you should buy most of your mechanical parts from mcmaster or other distributors
--dan.
Unread 02-02-2007, 18:32
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I've had nothing but good service from them in years past. But yes, a lot of the stuff isn't actually coming from them.
Heads up! Billfred Control System 9 30-07-2004 12:37
Analog in on OI: Heads Up! Astronouth7303 Programming 5 05-02-2004 17:55
Bouncing heads.... archiver 2001 2 24-06-2002 00:14
