Go to Post If your goal is to win matches... Pick the most capable candidate. If your goal is to change lives... Sometimes you pick those that need the most change. - IKE [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
  #33   Spotlight this post!
Unread 02-02-2007, 19:29
WillZZZ's Avatar
WillZZZ WillZZZ is offline
FRC #0503 (Frog Force)
WillZZZ will become famous soon enough
Send a message via AIM to WillZZZ Send a message via Yahoo to WillZZZ
Unhappy Re: USB Joystick adapter is here!
These are the values we are getting from the Dashboard plugged directly into the OI. The Chiklet is in the regular mode and on the left analog axis, putting the axis straight up yields max values of 15 or 16 on the Y and also 15 or 16 on the X when the axis is straight to the right. When the axis is straight down and left, we get normal values of 127 on the X and Y. This same phenomenon is occuring on the right analog axis going straight up yields 14 or 15 on the Wheel and 14/15 on the Aux going straight to the right. Going straight to the left we get the normal value of 127 on the Aux and going straight down we also get the normal value of 127 on the wheel. This is mode 2 on the Logitech Dual Action gamepad which is supported according to your manual. We have tried different modes and they yield the same results. As you can see on our Logitech Dual Action gamepad, when the analog sticks on going full up or to the right they yield only a max of 15/16 or 14/15 instead of the full 127 like normal. The joystick itself I believe is NOT defective as I have plugged it directly into the computer, loaded the drivers and it works fine in Windows. Maybe this is a newer hardware revision of the Logitech Dual Action Gamepad? Anyways our team due to this problem is switching to the Wired Xbox 360 controller. Hopefully this is a isolated problem for the Logitech Dual Action gamepad.
--Will
intelitek loader/vex USB-serial adapter driver MrForbes Programming 2 07-04-2006 13:37
USB serial adapter for OSX? Validius Programming 1 05-01-2006 01:43
USB-Serial adapter Bill_Hancoc Chit-Chat 4 03-01-2006 07:18
USB to Serial adapter John Gutmann Programming 7 09-05-2005 01:34
BAFO USB to 9 Pin Adapter Skiguy523 Programming 2 29-01-2005 01:49
