Go to Post IF teams did NOT READ THE FIRST MANUAL AND Q&A SITE, it is not FIRST's fault, it is the TEAM'S fault - sburro [more]
Unread 02-02-2007, 17:08
rohit's Avatar
rohit rohit is offline
Inventor Person
FRC #0617 (The Springers)
rohit has a spectacular aura aboutrohit has a spectacular aura about
Send a message via AIM to rohit
Punching Holes
Can someone please tell me how to make thse type of holes on inventor?
http://img62.imageshack.us/img62/9706/phot0021sd5.jpg
http://img62.imageshack.us/img62/5362/phot0023ob5.jpg
Unread 02-02-2007, 17:16
AdamHeard's Avatar
Lead Mentor
Re: Punching Holes
You for the punched face, you could put a filet on it.
for the other side, you could extrude a ring, and then put a filet on either side of it.
I just tested it now, and was able to make a decent looking dimple dye (that is what they are called, right?) hole. I can't make the exact radius as I don't have any punched pieces in front of me, but I bet you can handle it.
Unread 02-02-2007, 17:23
Ericgehrken's Avatar
Ericgehrken Ericgehrken is offline
AKA: 3 Teams in 3 Seasons
FRC #0190 (Gompei and the Herd)
Ericgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud of
Send a message via AIM to Ericgehrken Send a message via Yahoo to Ericgehrken
Re: Punching Holes
You could extrude with a taper and do a rectangular pattern if you have to make many of them.
Team 3125
GHAMAS FIRST Robotics
Team President and Founder
2010-
2010 Suffield Shakedown Winner Thanks 178 and 177
2010 WPI Regional Rookie All Star
2010 WPI Dean's List Finalist
Team 195 Member 2007-2009
2007 CT Regional Winner Thanks to 1124 and 558
2008 FIRST Presidents Circle Winner
2009 Suffield Shakedown Winner thanks to 126 and 1124
Unread 02-02-2007, 20:17
rohit's Avatar
Inventor Person
Re: Punching Holes
Thanks for all the help. I'll try that tomorrow (when I have the software available to me) and tell if I could do it
Unread 02-02-2007, 20:29
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: Punching Holes
Good suggestions if you want it to be symmetrical. However, it appears to me that they are slightly offset. For this effect I would use a loft. I will agree with the others, though, in saying that the tapered extrusion will work just fine.
Unread 03-02-2007, 03:52
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
Re: Punching Holes
If you know the angle of the punch, the "hole" feature with a countersink would work. If you only know the two diameters of the holes, loft would be fine, as would a revolve that cuts (but that involves sketching off of an odd location).
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 03-02-2007, 11:04
Molten's Avatar
AKA: Jason
Cool Re: Punching Holes
If you are going to go to that much effort there is still one alternative. Just extrude and then chamfer.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 03-02-2007, 19:19
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Re: Punching Holes
I think in the sheet metal feature, there is a "Punch" feature. Try that as well.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 04-02-2007, 20:16
rohit's Avatar
Inventor Person
Re: Punching Holes
The loft worked better than perfectly! Thanks
I made 2 sketches and connected the two together with loft and it worked!
I'll be done making all the holes by tomorrow.
Unread 04-02-2007, 21:09
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
Re: Punching Holes
The Hole tool with countersink is the best option. You don't even need any sketches, so it's fast and simplest to process.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 05-02-2007, 11:54
Molten's Avatar
AKA: Jason
Re: Punching Holes
Though it needs less complicated sketches, it still needs them. Otherwise it does not know where to put the hole.
Unread 05-02-2007, 12:24
7
FRC #1712 (Dawgma)
Re: Punching Holes
The Hole tool allows you to define the location of the hole by inputting the distances between the hole center and surface edges. I don't remember what the option is called, but the Hole dialog box has a drop down menu to choose how the hole location is defined.
Unread 05-02-2007, 15:37
Molten's Avatar
AKA: Jason
Re: Punching Holes
That is interesting, I will check into that. I have yet to hear about that ability. How many years have you been learning Inventor?
Unread 05-02-2007, 17:15
Wedge34's Avatar
Wedge34 Wedge34 is offline
FRC #0868 (TechHOUNDS)
Team Role: Student
Wedge34 is an unknown quantity at this point
Re: Punching Holes
You can just use the hole tool and make it a counter sink.
the easy way
Unread 05-02-2007, 22:38
7
FRC #1712 (Dawgma)
Re: Punching Holes
I started Inventor 2 years ago, in 9th grade. But don't think it takes that long to learn Inventor at an advanced level--I'd say that I learned 90% of my Inventor knowledge in only a few months, when I really looked through the manuals that came with the program, and followed some of Sean Dotson's and J. D. Mather's tutorials.
Angled holes? [527]phil Inventor 22 09-02-2007 12:59
Moving holes in an assembly? Eric Scheuing Inventor 10 04-02-2006 13:56
Machine weight and holes archiver 2000 0 23-06-2002 22:51
Drill holes nick reynolds Rumor Mill 10 12-01-2002 01:39
Distance Between Holes in Blocker? Jim Meyer OCCRA 1 08-10-2001 09:59
