Go to Post We can't quite define FIRST according to past standards and traditions, because it is shaping the future and does not conform to today's model of sports. - JaneYoung [more]
Unread 02-02-2007, 16:18
ejSabathia's Avatar
ejSabathia ejSabathia is offline
AKA: EJ Sabathia
ejSabathia has a reputation beyond reputeejSabathia has a reputation beyond reputeejSabathia has a reputation beyond reputeejSabathia has a reputation beyond reputeejSabathia has a reputation beyond reputeejSabathia has a reputation beyond reputeejSabathia has a reputation beyond reputeejSabathia has a reputation beyond reputeejSabathia has a reputation beyond reputeejSabathia has a reputation beyond reputeejSabathia has a reputation beyond repute
pic: table shot of the wheels... 254/968
Unread 02-02-2007, 16:19
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
Re: pic: table shot of the wheels... 254/968
Those look good, who is making them?
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 02-02-2007, 16:20
AdamHeard's Avatar
Lead Mentor
Is it an illusion, or are they smaller than last year?
If so, is that another move to save weight?
Unread 02-02-2007, 16:25
Andrew Blair's Avatar
FRC #0306 (CRT)
Here's a question- on the interior portion of the wheel, the tread holding portion- if you're just going to cut the back of the plate off, why do you pocket the entire interior, instead of just contouring the inside of the wheel? It would definitely save a lot of time but I can imagine that chunk of aluminum bashing up your wheel when you turned the block off it.
-Sir Francis Bacon
-Albert Einstein
Unread 02-02-2007, 16:57
AdamHeard's Avatar
Lead Mentor
I don't know why. The machinist did the same thing when they made our wheels though, so there must be some reason for it.
Unread 02-02-2007, 23:12
Philip W. Philip W. is offline
Philip W. is a splendid one to beholdPhilip W. is a splendid one to beholdPhilip W. is a splendid one to beholdPhilip W. is a splendid one to beholdPhilip W. is a splendid one to beholdPhilip W. is a splendid one to behold
My guess is that if you do a contour, you have to make a breakthorough cut and go through a piece of wood or something that the aluminum is mounted to. Mounting the aluminum requires so much effort, especially for all those wheels, when you can just do what's done in the picture and then flip the pieces upside down and face it all off.
I'm no expert machinist; I started learning how to use CNC a week ago. Correct me if I'm wrong, please.
Unread 02-02-2007, 23:15
FRC #0306 (CRT)
I didn't really mean to cut all the way through the piece- just contour the inside edge, then do whatever machining operations later to free the wheel from the blank. I would imagine that for these wheels, a contour to the same depth would take far less time than the full pocket they're taking out of the wheels. And save some more of that precious 7075!
-Sir Francis Bacon
-Albert Einstein
Unread 02-02-2007, 23:57
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
Its not an illusion. The wheels this year are 4" diameter.
Unread 03-02-2007, 03:00
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
It looks like the wheels are wider too... Are they 4" x 2" wheels?
Team 1538 / The Holy Cows, 2005-2016
Unread 03-02-2007, 03:03
Joel J's Avatar
Joel J Joel J is offline
do you..
Interesting.. did you design to be able to climb ramps, or is that not a part of the strategy this year?
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 03-02-2007, 04:43
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
The wheels have ~.85" tread width. Wider than last year by a small amount.
And yes, the robot will have the ability to drive up ramps.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 03-02-2007, 17:01
Guy Chriqui Guy Chriqui is offline
AKA: Guy Chriqui
FRC #0004 (Element)
Guy Chriqui is just really niceGuy Chriqui is just really niceGuy Chriqui is just really niceGuy Chriqui is just really niceGuy Chriqui is just really nice
Is it worth making it out of plate instead of roundstock? It seems like the smarter way to go in terms of machine time and I am thinking of altering our machine process for our wheels next year based on these. I am curious as to how long these wheels take a piece and if it is worth the extra wasted material.
-Guy
team4element
Unread 03-02-2007, 18:28
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
-Guy
It's approximately 30 min runtime for each piece. Using plate instead of roundstock saves a lot of time. It can all be done on the mill, instead of needing to either saw/part pieces off of roundstock, then face them, then turn them to the correct OD, before even being able to start the contouring.
2001-2004: Team 100
2006-Present: Team 254
Unread 03-02-2007, 20:22
Engineering Mentor
FRC #0254
It is also more difficult to get ahold of 7075 round stock in the diameters required.
-Travis Covington
pic: 254 and 968 on Newton alphaone Extra Discussion 10 17-02-2007 08:28
pic: Anodized Parts 254/968... ejSabathia Extra Discussion 12 02-02-2007 15:31
pic: Group shot Carol Extra Discussion 1 24-10-2006 09:32
Question for 254, 22, 968, 60, or 22 sanddrag Technical Discussion 1 13-01-2006 09:49
pic: At the Scoring Table CD47-Bot Extra Discussion 8 21-07-2003 22:07
