Go to Post Snow Blower Motor? Forget the water game, how about a snow game? - Gary Dillard [more]
Unread 03-02-2007, 03:29
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
Re: Banebot 56mm gearbox - double D - RELOADED
Originally Posted by AcesPease View Post
I would like to add that we used smaller Banebots transmissions last year for Mabuchi and Fisher Price motors and found the quality and service excellent.
Agreed, we used a 36mm, 256:1 gearbox to reduce the speed of a FP motor for ball harvesting last year. Worked well... Then again it was used for ball harvesting (which put very little load on the motor) not lifting an arm.
If a solid solution cannot be found in the next couple of days I would recommend that teams planning on using the 56mm gearboxes to drive their robot should seriously consider the single speed AndyMark (http://andymark.biz) gearboxes. They're the closest thing to last years kit transmissions, in fact I believe they might even be lighter than the old kit transmissions. At $98 a piece these teams should ask themselves if a headache is worth $200 +shipping.
Team 1538 / The Holy Cows, 2005-2016
Banebot 56mm gearbox - double D related Joe Johnson Motors 78 31-01-2007 23:55
small banebot motor with 64:1 gearbox burkey_turkey Motors 16 29-01-2007 01:48
Banebot Gearbox chris31 Technical Discussion 45 15-01-2007 17:56
Attempting to Cut BaneBot 56mm Shaft edthegeek Motors 6 15-01-2007 08:51
56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? VEN Technical Discussion 4 11-01-2007 14:45
