Go to Post How the mentors of a team inspire their team is unimportant, as long as the team is inspired to do great things. We on 1824 believe in 'student designed, student built', but that does not mean that all teams should do as we do. For inspiration comes in many forms. - Daniel_LaFleur [more]
Unread 02-02-2007, 12:33
razer razer is offline
FRC #1690
razer is an unknown quantity at this point
printing FLOAT data type on the terminal window
I have a question -
can i print float variable on the terminal window?
for example:
float a=2.555;
a*=4.5;
printf("a = %f", a);
does the RC prints float vriables on the IFILoader's Terminal Window?
Unread 02-02-2007, 12:40
AKA: Dr. Brooks
no team (WRRF)
Re: printing FLOAT data type on the terminal window
Originally Posted by razer View Post
I have a question -
for example:
float a=2.555;
a*=4.5;
Last I checked, the printf in PIC support we use did not support floats. Floats, and doubles, are in general a bad idea on this processor. I reccomend fixed point, or aritimetic using rational numbers. See http://srvhsrobotics.org/eugenebrooks/IntroCProg.pdf There is a routine described in this document, and available for download, that prints fixed point numbers.
Eugene
Unread 02-02-2007, 12:52
FRC #0701 (RoboVikes)
I don't think it's that bad to use a couple floats, but overuse can lead to slow downs in processing time.
the use of floating point numbers is not native to the PIC, Instead MPLAB uses a software routine to do the math (this is done at compile time), internally everything is probably represented differently. So everytime you do a float there extra steps the processor has to take.
If you want to printf it you could just multiply by 100 or 1000 or however much accuracy you want and then cast it to an int.
Team 701
Unread 02-02-2007, 13:59
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
The RC (actually, the microcontroller) does not have hardware support for floats. It supports floats software-side, but it is very slow.
Unread 02-02-2007, 14:15
http://www.chiefdelphi.com/forums/sh...89&postcount=6
Unread 02-02-2007, 16:33
CrashOverride's Avatar
CrashOverride CrashOverride is offline
FRC #1831
CrashOverride is an unknown quantity at this point
I looked at the source for the libraries last year and float data type is not included in the vfprinf routine, the code behind printf. Your best bet is to multiply your float by 100 or 1000 depending on how many deicmals you want put the result in a long and printf the result. Aviod floats whenever possible!
Unread 02-02-2007, 19:10
Jared Russell's Avatar
Taking a year (mostly) off
If enough people want to be able to print floats, I'll write code to do it (by decomposing the float into sign, exponent, mantissa). It'll take a couple hours.
Let me know...I'm always looking for something to do.
Unread 03-02-2007, 04:09
FRC #1690
i asked that because we have a function to calculate the range between the robot and the Rack, and it depends the TILT angle of the camera.
the TILT ANGLE is being used as an integer, so if the angle is 8, then the distance is 9 meters. if the angle is 7, than the distance is 6 meters. i want something in the middle like 6.5 angle and so on, to be more accurate.
but thanks ill use something i saw here, you can see this thread as closed.. thanks
Unread 03-02-2007, 04:12
FRC #1690
if you have a smart way to prints floats, so it will be very usefull here i think. but i saw a reply in this thread which says to print it like " %d.%d ", but if you have another way.... it will be usefull, thanks.
Unread 03-02-2007, 09:25
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
The prinf function isn't capable of printing floats. Instead convert your float to an integer and multiple it by 100.0. Use %d and print it. That should work.
float tan = -12.423421;
printf("Tan is = %d\r\n",(int)(tan * 100.0));
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 03-02-2007, 18:17
The yellowdart's Avatar
The yellowdart The yellowdart is offline
FRC #1506 (Metal Muscle)
The yellowdart has a little shameless behaviour in the past
Floats are bad to use. They are bad because sometimes you get ridiculous numbers, for instance
23.98071849629364097134098729873403214
or larger. It runs slowly because it takes up extra memory, and there is a limited amount of memory in the controller.
Good luck
Unread 04-02-2007, 11:27
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Floats aren't necessarily bad if used in moderation. They don't take any more data memory than a long does as both float and double are 32 bits long. Floating point operations are emulated in software since there is no on-board FPU hardware. The math library linked in uses a modest amount of additional program memory - but there is a lot of program memory available. It doesn't cost any more program memory to do 1 or 1000 float operations once the library is linked in.
What a programmer needs to be aware of is that the software emulation of the floating point operations can take a lot of time. How much time? I wrote a program to test how many floats/second the library could support and it wasn't much... maybe a few 1000s/second and you'd be saturating the PIC. I'll have to go back and re-run the benchmark to remember exactly.
The float/double data type is 8 bits of signed exponent and 24 bits of data - so a 32 bit integer value actually has 8 bits more precision than a float.
As with anything, understanding its weaknesses as well as its strengths will allow you to make a well informed decision based upon tradeoffs. Personally, I try to avoid both longs and floats but sometimes it just makes more sense to use them vs anything else.
Unread 04-02-2007, 19:30
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
What do you mean by 'more precision' in this case?
Thanks,
Robinson
Unread 05-02-2007, 02:12
AKA: Bud
For the same exponent, which is what you'll get when you align float exponents for math operations, you only have 24 bits to represent your number. Longs are 32 bits. Using fixed point arithematic with longs is more precise than using floats as longs have 8 more bits of data than floats.
Unread 05-02-2007, 08:55
Metalgod4eva Metalgod4eva is offline
None #0870
Metalgod4eva is an unknown quantity at this point
Just a quick interjection if you use Floats or Doubles dont forget to format your output with %.Xf. The X is what place you want to format after the decimal. like %.2f outputs to the thousands place || x.00. If the decimal is not a double watch out for grabage data allways do some form of formating on the %F output because on a system there is a max and min a float can be, after that the system literaly gives you garbage and if your working on something that has to be exact then dont forget, in also to that comment if you want things exact then use intergers computers like base 2 and 1 && 0 so if you want to drive the robot 2.3 try to rework your measures 1 place value and move the values down a place value. have a great day!
Com Terminal 1 Window Problem. groovy69 Programming 4 25-01-2007 22:58
Terminal Window teh_pwnerer795 Programming 1 02-01-2007 00:21
Terminal Window Idaman323 Programming 0 20-02-2006 19:28
Placement of the SLU-35 Terminal Lugs gumbyman-829 General Forum 8 03-02-2006 00:57
Is Terminal Window Evil? Fat Alex Programming 1 20-07-2004 10:57
