Go to Post still emotion conveyed through text is really strange. - Blackphantom91 [more]
Unread 03-02-2007, 07:54
65_Xero_Huskie's Avatar
65_Xero_Huskie 65_Xero_Huskie is offline
One T
AKA: Mat
65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute65_Xero_Huskie has a reputation beyond repute
Re: PWM Problem with Default Code
Originally Posted by ballasingh09 View Post
We had this problem earlier and what we had to do was switch the output wires of one of the drive victors. Once we did this, our drive worked properly.
Same here, you should check all of your connections just to make sure. WE spent about 30 minutes trying to figure out why we couldnt turn left or right...maybe the PWM cables should be in the right spot..
Min-Max to the Max!
Problems with Kevin's 2007 default code bruss6 Programming 8 19-01-2007 15:42
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Default code problem capenga Programming 8 01-02-2005 08:09
problem with the default code MarkVH Programming 7 28-01-2005 00:04
Problem with FRC Default code AsimC Programming 2 11-01-2004 19:22
