Go to Post TL;DR: The robot battery (and your car battery) aren't going to electrocute you unless you stab a positive and negative wire from them into your heart. In which case you have plenty of other problems besides. - Kevin Sevcik [more]
Unread 31-01-2007, 20:45
G-Ball's Avatar
G-Ball G-Ball is offline
FRC #2178 (Riobotics)
Team Role: Student
G-Ball is an unknown quantity at this point
The Rack movement
Is the entire rack moved at the beginning of the round? if so do the lights also move with it or are they stationary? Or is it that they just shake the spiders before each round? Thanks for your help.
Unread 31-01-2007, 20:49
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Re: The Rack movement
Yes, the rack is moved before the beginning of every match after the teams set up their robot. The lights will stay in the same location on the rack above the spider legs.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 31-01-2007, 21:54
ham90mack's Avatar
ham90mack ham90mack is offline
President of RIT FIRST
FRC #0073 (The Illumination)
ham90mack is just really niceham90mack is just really niceham90mack is just really niceham90mack is just really niceham90mack is just really nice
The rack is rotated somewhere between 0 and 45 degress (I am guessing) before the match is started. This causes the spider legs to change location, along with the lights above them.
Unread 31-01-2007, 22:02
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
It can be rotated as much as the field crew wants, but because it is symmetrical every 90º, it effectively has 45º of rotation.
Unread 02-02-2007, 22:23
GMKlenklen's Avatar
GMKlenklen GMKlenklen is offline
The "Masonater"
AKA: George Mason Klenklen
FRC #2167 (MASMabots)
GMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to all
Send a message via AIM to GMKlenklen Send a message via MSN to GMKlenklen Send a message via Yahoo to GMKlenklen
also, if you observe the movement of the spider legs...
the top leg moves horizontally the least of all 3 levels of legs
followed by the second level's horizontal movement
followed by the bottom level's horizontal movement!
this means that it may possibly be easyer to score on the top level during autonomus mode... although the dampening time for the rack is around 10 seconds, maybe more if they really turn it!
Thank you,
formerGrand Master Klenklen
-of the MASMabots-
Unread 03-02-2007, 08:03
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Don't foget there is 6 inches of play in the chain and it can move side to side and front to back +-6 inches.
Doug Leppard
the rack Big-Bird08 Technical Discussion 2 26-01-2007 17:52
Modeling The Rack. Eric Scheuing Inventor 22 16-01-2007 19:51
Images of The Rack K1llerteddybear General Forum 2 11-01-2007 17:01
pic: The Rack Ryan Foley Extra Discussion 13 08-01-2007 23:46
It's Time To Start- Rock Concert Movement #1- The Basic Head Bob... Joe Matt Chit-Chat 5 21-04-2003 10:00
