Go to Post There are no guarentees in life. Cherish what you have while you have it. None of us knows what tomorrow will bring. - KenWittlief [more]
Unread 03-02-2007, 02:08
Dave K.'s Avatar
Dave K. Dave K. is offline
Engineer/Mentor
FRC #0930
Dave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to beholdDave K. is a splendid one to behold
7.2V NiCd Battery Substitute
For teams operating one or more cameras, servos, or other electronics powered from the 7.2V NiCd battery, and who don't necessarily want to power these loads from the main battery by way of the requisite build-it-yourself IFI charging circuit... I wanted to share some test results.
I purchased four Tenergy brand, 2100mAh, 7.2V NiCd battery packs for about $9 each. After charging the batteries with a smart charger, I discharged the batteries with a programmable DC load set to 500mA and periodically made note of the terminal voltage of the battery pack.
After two charge/discharge cycles, each of the battery packs showed pretty much the same capacity and easily provided 3 hours of use before reaching a discharged state of 1.0V/cell (6.0V). In other words at roughly 2.4 times the current of a 10 Hour discharge rate, the batteries produced better than 1500mAh of capacity.
Information you may not be able to find online:
Weight: I measure 11.5 oz, some websites claim 10 oz.
Battery Size Type: Sub-C
Overall Size: 5.25" long, 1.81" wide, 0.92" thick.
Battery pigtail length: 5.0" (measured from top of pack to tip of connector)
Connector type: Tamiya
The mating connector can be found at Radio Shack, P/N 23-444. This is a "repair kit" and contains both connector sex's with short leads and butt splices. Online and local hobby stores also carry this connector. Thus far I have been unable to find any electronic components distributor that stocks a compatible connector.
Some website URL's links to sellers:
http://www.batteryjunction.com/twoni721bapa.html
http://www.batteryjunction.com/oneni721bapa.html
http://www.onlybatteries.com/showite...t1=12&uid=1010
http://www.megabatteries.com/item_details2.asp?id=13679
https://www.all-battery.com/index.as...ROD&ProdID=434
These are toy battery packs, so you should be able to find these, or one of a very similar make, at local hobby stores or other online retailers. Capacity claims for similar sized batteries range from about 1500mAh to 2100mAh.
Radio Shack P/N 23-036 is a kit consisting of a 2000mAH 7.2V NiCd, a 1000mAh 9.6V NiCd, and a charger. If you are looking for a 9.6V rechargeable battery to make your operator interface portable, and get a higher capacity battery for your robot's backup battery, this might be a quick option that you can find locally. The mating plug for the 9.6V battery should be 23-445.
Remember, for the FIRST competition you may substitute any commercially available, 7.2V, NiCd battery pack. At competition it must be charged with the charger supplied in the Kit-Of-Parts (or by the build-it-yourself IFI on-board charger).
--Dave
Unread 03-02-2007, 11:04
Dave K.'s Avatar
Engineer/Mentor
FRC #0930
Re: 7.2V NiCd Battery Substitute
Additional information that may be helpful are the correct part numbers for mating with the existing NiCd battery connectors.
These are Tyco Electronics (AMP), Mate-N-Lok series connectors.
1-480318-0, Housing Plug
1-480319-0, Housing Receptacle,
60618-1, Pin Male, 18-24AWG
60617-1, Pin Female, 18-24AWG
These are stocked by Mouser, Digikey, and others. Pricing depends upon quantity purchased. Mouser currently has each of the part numbers priced at 13 cents each in quantity one.
The "Plug" and Female pins are used ON the supplied battery.
The "Receptacle" and Male pins are used ON the robot controller side.
The Tamiya connector holds the pins in place better and the connectors just click together without a problem. The Mate-N-Lok connectors always seem to take a bit of wiggling to get the pins aligned. When in a hurry, I've even had the pins pop out of the back of the connector as I tried to mate them.
Given a choice of the Mate-N-Lok or Tamiya connector, I would standardize on the Tamiya, and make a Tamiya to Mate-N-Lok adapter so that the battery could be charged with an unmodified plug in charger.
--Dave
12 Volt Battery Substitute maniac_2040 Electrical 6 21-01-2007 00:43
Gasoline substitute? Bcahn836 Chit-Chat 13 30-05-2004 18:55
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
Battery M.I. Technical Discussion 1 04-02-2002 17:13
Substitute Parts BHSFirst Off-Season Events 1 08-11-2001 19:23
