Green Light For Vision System Angle & Distance
We cannot find what angle the green light for the vision system is for a mock up field rack. Also, how far does this hang over the edge, how long is the mounting piece? Thank You!
2181 Blaine, MN ![]() |
Re: Green Light For Vision System Angle & Distance
Your question would get much better exposure and support in the Technical Discussion subforum.
This subforum is for any issues or questions on the forum itself. You do get a cookie though for having a clear and to the point thread title. ![]() |
The answer can be found in the Official FIRST Field Drawings. In particular, check the drawing labeled "Field Rack Fabrication(2)", part #1. It shows the cut angle for the light support, and the length of the offset from the center of the Rack to the light mounting position.
-dave |
| Green light same color as overhead light | Ethulin | Programming | 13 | 02-08-2007 15:24 |
| Parts for Green light | Andrewpbhs | Technical Discussion | 2 | 25-01-2007 20:59 |
| camera trouble,cant tell the green-light from regular white light | Nimmy | Programming | 26 | 14-01-2007 14:53 |
| Green Light | Rachika Garcia | Kit & Additional Hardware | 1 | 10-01-2006 08:46 |
