Go to Post Sometimes i wish the robot could fit into my pocket. - GMAdan [more]
Unread 03-02-2007, 13:05
robobrain0101's Avatar
robobrain0101 robobrain0101 is offline
FRC #1054 (The Knightmares)
robobrain0101 is an unknown quantity at this point
Send a message via AIM to robobrain0101
Older Sprokets
Team 1054 is currently in possesion of a 9 tooth sproket and a 45 tooth sproket from older kits and would like to know if we can use them on our robot this year. If anyone has information about this please respond.
Unread 03-02-2007, 13:21
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Re: Older Sprokets
You can as long as they were not made especialy for FIRST. Example: a sprocket with a FIRST specified bolt circle to mate with drive wheels would not be allowed. Anything that you can find available thru vendors like Grainger or McMaster Carr is OK. The sprockets you're talking about should be OK to use.
Unread 03-02-2007, 13:51
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Re: Older Sprokets
To my knowledge of the 2005 and 2006 kits, they did not include either a 9 or 45 tooth sprocket. If you are talking about the kit sprockets that bolt to the skyway wheels, then no, you cannot use these. They include a special hole pattern, that IS the same dimensions as the AndyMark and IFI wheels, but has different features than the 07 sprockets.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Older TV Shows D.J. Fluck Chit-Chat 88 07-03-2007 01:45
A source for double strand sprokets.. dfukuba Technical Discussion 5 30-12-2006 14:42
Older Games aubinhick990 Website Design/Showcase 1 06-03-2006 18:36
[OCCRA]: 40t sprokets troy_573 OCCRA 1 26-09-2005 00:23
Titanium chain & sprokets rubicondsrv Kit & Additional Hardware 16 27-01-2005 13:00
