Go to Post Those four stages will most likely be supplanted with the more aptly named phased approach: "Don't Panic", "Consider Panicing" and "Why havent we been panicing?" - Dan Richardson [more]
Unread 03-02-2007, 13:28
AaronTeune AaronTeune is offline
FRC #1721
AaronTeune is an unknown quantity at this point
Mounting Geartooth sensor!
This year they changed up our gearboxes with the Banebots 12:1 Transmission. I know how a gear-tooth sensor works and how it should be mounted in relation to a gear, I just don't know where what gear to mount it to. Does it go somewhere in the transmission or what? If someone could possibly take a picture of their robot w/ the gear tooth sensor attached and post it or e-mail it to me that would be very much appriciated.
Thanks in advance!
Unread 03-02-2007, 21:58
Re: Mounting Geartooth sensor!
Aaron,
The gear tooth sensor is intended to count any rotating part that has indentations. A gear or sprocket is what is needed. You will have to make a bracket to hold it in place and position it experimentally until it counts and gives you valid data. The documents go into some depth on this part. Without a look at your robot, it is hard to give more specific suggestions.
Unread 04-02-2007, 01:34
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
The gear tooth sensor will not give you direction info.
There is an add-on Banebot option for a quadrature encoder, that mounts on the outboard (wheel-side) shaft of the Banebot motor.
GearTooth Sensor Destroying Hopes of Autonomous~!!!!!! Prgrmin' Programming 36 28-02-2006 19:07
Mounting the Gear Tooth Sensor??? blue_crew Electrical 3 09-02-2006 13:53
Sensor Mounting Aplications Jimmy Holmes Electrical 5 13-02-2005 13:34
Sensor or no Sensor For Autonomous mode Kyle1010 Programming 14 22-01-2003 13:10
