Go to Post Begging, yelling, kicking, and screaming for members of my team to send me updates while I'm at college not doing homework. - Ginger Power [more]
Unread 03-02-2007, 14:03
kbregler kbregler is offline
FRC #1791
kbregler is an unknown quantity at this point
Re: PWM Problem with Default Code
Deleting those 2 lines of code seemed to fix the 1 joystick problem, thanks.
Now I just need to figure out why the PWM1 light is mapped to the x axis
Kevin
Unread 03-02-2007, 15:14
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Originally Posted by kbregler View Post
...This indicates that in the program somewhere the x and y axis are getting swapped.
Now I just need to figure out why the PWM1 light is mapped to the x axis.
The axes were kind of swapped by that code you just deleted (and using pwm05 as a temporary variable, terrible programming practice), so you should have fixed the PWM1 LEDs as well. Could you test it again?
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Problems with Kevin's 2007 default code bruss6 Programming 8 19-01-2007 15:42
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Default code problem capenga Programming 8 01-02-2005 08:09
problem with the default code MarkVH Programming 7 28-01-2005 00:04
Problem with FRC Default code AsimC Programming 2 11-01-2004 19:22
