Go to Post Big scoop for everyone here: All divisions are stacked with talented teams. It's like this is a really big event or something. - PayneTrain [more]
Unread 03-02-2007, 17:16
Inoperational Inoperational is offline
FRC #1506
Inoperational is an unknown quantity at this point
Calculating Camera Distance
We have the camera set up on our robot, but we are having some very annoying problems. When we hook up our laptop to the rc, it shows the distance being anywhere between -30 to 67000. If anyone has any idea on the equation for calculating distance from the camera to the green cathodes, please post here. Thanks
Unread 03-02-2007, 17:36
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
Re: Calculating Camera Distance
Kevin Watson has an idea, why not try here
http://kevin.org/frc/2007_frc_range_calc.pdf
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Unread 03-02-2007, 18:04
FRC #1506
we have that already and it is still not working
Unread 03-02-2007, 18:39
Skysong Skysong is offline
FRC #0610
Skysong is an unknown quantity at this point
Are you able to get different tilt angles when you move the robot manually towards the light? We did that as an initial test and had the robot stop when it was ten feet away from the light.
Are you using Kevin's default camera code? That seemed to work fine for us.
Unread 03-02-2007, 18:48
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Make sure when you are printf'ing you cast the data as an unsigned int.
http://www.mikesorrenti.com/
Unread 03-02-2007, 18:57
The yellowdart's Avatar
The yellowdart The yellowdart is offline
FRC #1506 (Metal Muscle)
The yellowdart has a little shameless behaviour in the past
Where in the code is the angle defined?
Unread 04-02-2007, 23:48
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
Look in terminal.c at the printf()s that print information when the camera has found a target. If you #include the camera header files, you can use the same information that is printed regarding the tilt angle. Just copy all of the math and assign it to a variable in your code.
What place are we at? ... TODAI!
calculating distance sur2124 Programming 10 15-03-2006 18:36
How do I get distance between Camera and the target? sjung9442 Programming 5 27-01-2006 09:44
Camera Tracking Maximum Distance MikeDubreuil Programming 0 18-01-2006 10:18
