Go to Post It all depends on which box your trying to think outside. - ItsPat [more]
Unread 03-02-2007, 18:12
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
Encoders not changing...
i implemented the encoder file from Kevin's site... but it doesn't work. I plugged it in to what it said, and i update it with:
        LeftWheelCount = Get_Encoder_1_Count();
        RightWheelCount = Get_Encoder_2_Count();
what could my problem be?
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 03-02-2007, 20:32
Joohoo's Avatar
Joohoo Joohoo is offline
FRC #0340 (G.R.R.)
Joohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really nice
Send a message via AIM to Joohoo Send a message via Yahoo to Joohoo
Re: Encoders not changing...
what other code is being implemented are you using the camera?...GTS?...timers?...other sensors?
make sure the encoder outputs are plugged into the correct inputs.
make sure you are using the right type of encoder, I believe that kevin watson has his code set up for a quadrature encoder.
also make sure that you call all the right functions in the right places ie. encoder_counter() in Interrupt_Vector_low(), encoder1_init() in user_init().
another problem that happened to me was overlapping interrupts. If you do a "find in project" for a bit in the register to see if they are used anywhere else, you may eliminate this problem.
Unread 04-02-2007, 00:03
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Did you follow the steps in the readme that came with the encode code.. such as adding the initialization call?
Unread 04-02-2007, 10:33
paulcd2000's Avatar
AKA: Paul Dagnelie
i did follow the steps in the initialization. i am also using the camera. I'll check the encoder type. Where do i find what kind they are exactly? I do call Initialize_encoders() in initialization, and i call interupt handler low from Default routine.
Unread 04-02-2007, 11:56
Originally Posted by paulcd2000 View Post
...i call interupt handler low from Default routine.
Don't do that.
The interrupt handler is "called" by a hardware feature of the processor. You don't have to do anything more than define it as the interrupt handler.
Unread 04-02-2007, 12:02
paulcd2000's Avatar
AKA: Paul Dagnelie
k thanks... still haven't gotten a chance to test again
EDIT: nope, still doesn't work...
Unread 04-02-2007, 16:01
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
How do you know the encoders are not changing? Are you simply trying to print your xxxxWheelCount variables to a terminal and noticed they don't change?
If so, then that's likely the only problem and your encoders are just fine. Your variables are probably declared long int and, as such, you need to typecast them before printing. Try the following:
printf("Left encoder = %d", (int)LeftWheelCount\r\n);
and see if it works. Sometimes the simple things really get on your way!
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 05-02-2007, 17:01
paulcd2000's Avatar
AKA: Paul Dagnelie
actually, they're not longs. they're ints. a long can hold up to 2147483648, which is about a mile. i just used ints. they're printed using
printf("Left Encoder: %d\t Right Encoder: %d\r", LeftWheelCnt, RightWheelCnt);
But it's a good point. i'll try printing the values directly from the method...
Unread 05-02-2007, 19:16
paulcd2000's Avatar
AKA: Paul Dagnelie
did anyone have to change their encoder code to get it working? what did you do? cuz ours still isn't working
Unread 05-02-2007, 20:45
I tossed a USB flash drive containing Kevin Watson's frc_encoder.zip file to the lead student programmer and told him to follow the directions in encoder_readme.txt. He did the nine required steps and compiled it. I added a tiny bit of code in Process_Data_From_Local_IO() to turn the raw encoder counts into odometer and heading information, and put a printf statement in Process_Data_From_Master_uP() to verify the proper operation of the encoders.
That's it. It was painless.
Unread 05-02-2007, 21:26
paulcd2000's Avatar
AKA: Paul Dagnelie
does the type of encoder affect the code? where did you guys get your encoders?
Unread 05-02-2007, 21:44
The code is designed to work with any encoder having a quadrature output. That means there are two signals, each producing a square wave signal as the shaft turns, but the A and B signals are a quarter-cycle out of phase with each other.
We're using US Digital's E4P encoders. http://www.usdigital.com/products/e4p/index.shtml
I believe we bought them from Newark Electronics, but I'm not the one who purchased them, and I'm not certain.
Unread 05-02-2007, 22:04
paulcd2000's Avatar
AKA: Paul Dagnelie
would the number of clicks per revolution make it more or less likely to work? because ours runs at 128 clicks per revolution, and some are concerned that that's too fast for the RC to detect
Unread 05-02-2007, 22:44
Jared Russell's Avatar
Taking a year (mostly) off
Make sure the encoders are wired right. You can leave the power pins plugged in and look at the signal wires with an oscilloscope or multimeter. If they change as you rotate the wheel, the problem is in the program. If not, there's an electrical problem.
Unread 05-02-2007, 22:50
paulcd2000's Avatar
AKA: Paul Dagnelie
k thanks, we'll try that
Changing Fields? Steve W Championship Event 8 08-04-2003 19:37
Changing Chairman's Jacqui Sutton Chairman's Award 1 03-04-2003 09:47
Changing gears archiver 2000 1 23-06-2002 23:26
::CHANGING SERVERS:: Brandon Martus General Forum 5 21-12-2001 10:33
changing my name Travis Covington CD Forum Support 1 09-10-2001 08:37
