Go to Post Please understand that teams run things differently for specific and very valid reasons. And, this is OK as long as the students are inspired. - Alexander McGee [more]
Unread 15-01-2007, 22:36
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: Team 116 OI Adapter board
I've always been so fascinated with the possibilities for the OI...
Last year (call me crazy), I tried designing a micro-controller that hooked to the dashboard port, which decoded the SERIAL and put it out to a CPLD, which then put it out to 7-Seg displays and a couple of LED-Matracies. This failed when I ran out of time, and my team told me that it was more important that the robot could move and stuff than have a cool OI (go figure?)..
Now you may be wondering: Why don't you use a laptop with Dashboard?
I wanted to try to develop some hardware to be able to do this instead of relying on a super-over-qualified computer to do the job. If I was able to do it, I was planning on submitting the designs up here so that other people could try it (The whole thing cost under 100 dollars.. Much more affordable then a laptop, let alone extra batteries...)
Anyway, getting back to the topic of this thread, this year I am thinking about running everything through ribbon cable. Essentially having boxes with lots of sockets in them accessible from the outside, and soldering ribbon cable to each pin, home-running it all to a box with a bunch of DIP switches on the outside to set which sockets are currently in use, with 4 DB-15 cables coming out of the box to the OI. This would allow for hookup of almost anything. They I could create adapters for parts that could allow them to simply be placed or removed from the sockets, in essence *Hot Swappable*...
OK, I'm rambling, and if you actually read this whole post I am surprised, but I love this kind of stuff.
Jacob
Unread 19-01-2007, 23:38
ECarlson's Avatar
ECarlson ECarlson is offline
AKA: Eric Carlson
#0116 (Epsilon Delta)
ECarlson has a spectacular aura aboutECarlson has a spectacular aura about
When you complete the development on either project, I'd love to see the photos and the write-ups.
My original idea was to use some sort of connector for each OI device (switch/pot/LED/etc.), like perhaps 1/8" audio plugs and jacks, so items could quickly be swapped, but it is essentially just as quick with the design we ended up building, and you don't need connectors, and you only have to solder the wires at the device end.
- Eric
www.InvisibleRobot.com Updated: August 24, 2008
Over 28,000 FRC & FTC Photos , Team 116 OI adapter board info
Unread 03-02-2007, 21:50
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
We just finished etching this year's version of our boards. The layout is essentially the same, but we tried photolithography this time. Much cleaner than the toner transfer method. They still need to be drilled, cut, and soldered though.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 23-02-2007, 00:06
ECarlson's Avatar
AKA: Eric Carlson
Very nice. Here's a photo of our circuit board for 2007. I also updated the information page with the photo and a couple details.
- Eric
Unread 23-02-2007, 09:08
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
That is actually pretty brilliant. While I was wiring the OI I was trying to keep it neat but it was still a mess in a way. I think that this way is much more organized and maybe I will try something more similar next year.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 23-02-2007, 10:20
Billfred's Avatar
Billfred Billfred is offline
The 2006 board was already pretty awesome, but the circuit board this year is just awesomeness to the extreme.
Unread 21-01-2008, 20:01
ECarlson's Avatar
AKA: Eric Carlson
Anything new this year? We're using the same board design as last year.
- Eric
Unread 21-01-2008, 23:17
eeeeweeezeee's Avatar
eeeeweeezeee eeeeweeezeee is offline
menace to public safety
FRC #0114
eeeeweeezeee will become famous soon enough
Send a message via AIM to eeeeweeezeee
the prototype OI switches that I hook up have lately consisted of the 15pin connector, a piece of pwm signal wire with the connectors clipped off, random "switches"* and paper plates and bowls with holes poked in them for mounting. this is an extremely fast way to add the exact switch and potentiometer combination that the programmer wants, but I get some odd comments and have to explain that it isn't anywhere near the final revision. I had the idea for these ultra cheap and fast IO setups from being bored and trying to make a hovercraft out of spare muffin fans and paper plates, bowls, and cups. i'll post a picture if I get around to it.
*what ever i find first that conducts electricity and strikes my fancy, and some times has solder tabs
EEEEWEEEZEEE
was here
Unread 29-01-2008, 21:10
ECarlson's Avatar
AKA: Eric Carlson
Originally Posted by eeeeweeezeee View Post
. . . random "switches"* and paper plates and bowls with holes poked in them for mounting. . . . but I get some odd comments and have to explain that it isn't anywhere near the final revision.
I think that should be the final version, it would be kind of cool and original.
Some switches can take a lot of effort to toggle: How do you keep the paper plates from bending and tearing?
- Eric
Unread 17-02-2008, 00:05
ECarlson's Avatar
AKA: Eric Carlson
Here is the 2008 Team 116 OI adapter board. You'll notice that the pushbuttons were removed this year. I also added the photo to the OI adapter board web page on my site (link in sig below).
- Eric
[moderated]: Worst Call Ever and Congratulations from San Jose ducttapejason General Forum 45 12-05-2005 13:23
**FIRST EMAIL**/Welcome 2005 FRC Championship Teams! Andy Brockway FIRST E-Mail Blast Archive 1 04-04-2005 16:33
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
How Many FIRST shirts do you own? Joe Ross General Forum 81 31-08-2004 10:36
