Re: pic: Team 1345, end of week 4.
Robot looks great, but are you building that in a computer lab?
That seems like an inopportune place to build, with all the computers in danger. |
--- Arefin, after seeing yours and 1889's robot pictures...I'm scared for the Florida Regional. Great Job. |
I spy with my little eye...
Nice job 1345 guys, good to see your 06 bot is still in one piece too. |
Now that it's only 4 feet, how well can it score the top spider (if at all)? If it can, what method are you going to use to place them on the top spider?
Wow, this looks like a twin of our bot this year and we will be in Florida this year too.
How thick is the polycarb on the ramps?
#7
You haven't seen nothin' yet...
#8
Sean, to answer your question, yes it can score on the top one... but it takes time to line up and then try to score, so I will say, no we won't be scoring on the top spider. Today it came down to either going down to 4' and putting the ramps on or stay at 5' and be able to score on all 3 levels of spiders and have one ramp. Students thought it would be better to have two ramps and give up the top spider, so we went with it.
Travis, the lexan on top is 1/16". Jimmy, you are right. Florida regional will be packed with robust bots. Can't wait to compete against/with you. |
#9
Hey Arefin (and all the platinum Dragons),
I like the ramp system, seems like a good idea for a ramp system. I have a couple questions though. 1. What keeps robots from driving up your ramp, then driving right onto your chassis/electronics? I'm sure you thought of this, i just dont see the system in this picture. 2. How do you lower the ramps/platforms? can you raise them back up if need be? Just some food for thought. |
#10
1. We will put some kind of stop there (a bar of some kind) that will hold the robot back from hitting our arm or drive past the ramp structure and fall on the electronics. 2. How? we have few different ideas. I will share it with you and the community as soon as we figure out which would be the best way for us to do it. When raised the ramp looks like an upside down V. We don't want to raise the ramps back up once we deploy them. Plan is to drive back to the homezone with enough time to move all the tubes out of the way and then deploy the ramps for our alliance partners, giving them enough time to climb up. The ramp starts off at a 5 degree angle and slowly goes up to 20 degrees. |
#11
Do you think you're going to have room for guard rails, just in case the robot wasn't lined up straight as it was going up?
#12
Nice work 1345.
We will be climbing that ramp thats for sure. Keep up the good work. As for the Florida Regional , yes it WILL be insane |
#13
Looks good!!! I have some questions since you have tested yours already.
How grippy is the lexan cover? is it slippery or does it give them more traction? |
#14
Wowza, looks sharp great job guys.
My only question is that that looks like quite a bit deflection in your cross members of your ramp. Have you done any calculations or measurements to see how close you are to the edge of where yielding will occur? I would hate to see it begin to form itself into an unusable shape ( then again you can always replace it if or when that happens ) Also, did you drive the bot up the ramp or place it there? I'm kind of curious to how well that polycarb ( or acrylic? ) holds up when a robot kind of slams into it. It looks solid tho maybe its just the angle of the picture that looks like its causing that deflection. Maybe run some calc or even easier just some bench tests to see how when the dynamic loading / impact force of the robot running into and driving up the ramp will effect the integrity of those cross members. I'm sure you've already been beeting the heck of it hehe but just a reminder. Looks great, I'm deffinately gonna be scared to play you guys at UCF! |
#15
You guys plan to only have one ramp?
My mentor is trying to convince us, if we're overweight, to remove one drive motor on each side (right now we have two per side). I say we remove one of the ramps... We'll be better defensive, and we have a good manipulator. The ramp(s) will just help us get to the finals... then scoring should allow us to win. At least that's how I view it =/. |
| pic: team 1029 end of week 4... | bjimster1 | Extra Discussion | 7 | 04-02-2007 00:24 |
| pic: Team 1345, end of 3rd week. | Arefin Bari | Extra Discussion | 14 | 29-01-2007 08:44 |
| pic: Team 1345 New Designer | RuuD BoY | Chit-Chat | 2 | 27-01-2007 17:55 |
| prayers and support from team 1345 | Aakash Gihwala | General Forum | 70 | 26-01-2007 07:14 |
| pic: 1345 and 1523 | Arefin Bari | Robot Showcase | 4 | 20-02-2006 23:24 |
