Go to Post Thinking about this game within the confines of previous years will limit you. - Gregor [more]
Unread 03-02-2007, 23:16
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Re: AM Shifter Assembly Question
Originally Posted by squirrel View Post
Look at the transmisson, you'll see that there are some extra holes that can be used to relocate the spacers and bolts to clear the chain. The attatched drawing has circles around possible alternate spacer mounting holes.
Jim is right here, those extra holes are for alternative places to put the spacers in case your chain is wanting to run into them. Also, if you can't find a hole that gets the spacer out of the way, you could drill another set of holes.
As for the mystery white washers that Jeff was referring to in the original post, I will say here what I told him over a PM (or was it an email, I forget)...
Those white spacers are for customers who want their gearboxes tight. Some folks really don't like the side to side play that I prefer on the output shaft. So, they send an email or they call, asking for more of the small nylon washers (one for each gearbox). These can be put onto the output shaft between the sprocket and bearing on the outside (non-motor) wall, making there be absolutely no lateral play in that shaft. Maybe 10% of users want this. To me, it is easier just to throw another washer in with each loose hardware pack to make these folks happy.
Take care all,
Andy
servo on AM shifter JohnMorenski Technical Discussion 4 18-01-2007 13:46
Showdown: Shifter type CraigHickman Technical Discussion 7 21-04-2006 08:37
AM Shifter 2 question ForgottenSalad Technical Discussion 2 20-02-2006 14:26
AndyMark shifter feedback Max Lobovsky Technical Discussion 1 11-01-2006 22:26
Importing assembly into an assembly... James Green Inventor 8 22-01-2004 22:17
