Go to Post I don't know about you but i would love to have a grilled cheese maker in the workshop. - CMBrandon [more]
Unread 04-02-2007, 00:36
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Crazy Loops
Hey!
I'm trying to create a simple program that spins my bot for 20 seconds and sees how many tenths of degrees my gyro picks up. I've been programming for a long time, and I can't figure this one out. I'm using easyC because the rest of our team started coding with that, and I guess I'm stuck with it for this year....
Any way, here is some sudo code. Can't copy paste (It's not on this machine, but this is basically what it does)
Operator control
int gyro;
int timer = 0;
setgyrotype(4,125)
initgyro(4)
startgyro(4)
starttimer(1)
set_pwm(1,63)
set_pwm(2,63)
set_pwm(3,63)
set_pwm(4,63)
while(timer<20000)
gyro = getgyro(4)
timer = GetTimer(1)
PrintToScreen(gyro)
PrintToScreen(timer)
set_pwm(1,127)
set_pwm(2,127)
set_pwm(3,127)
set_pwm(4,127)
PrintToScreen("done")
Yeah, Yeah... Syntax. Semicolons are overrated. So are proper parameters. It's SUDO CODE....
Anyway... Heres where it breaks down.
It never leaves the while loop. The PrintToScreen SHOWS that the variable counts up to 20000, but continues to go around the loop after that. HOW DOES IT RUN THE LOOP WHEN THE CONDITION ISN'T MET???
Ive also tried an if statement inside the loop that checks the time and makes a variable 'done' 1, and I can show that at 20000, it becomes 1, but it still runs the while loop.
So what gives?
I just updated easyC to 3.0.1.1
I haven't tried this in the old version. Of course the same task in MPLab worked, and took half the time then clicking and dragging If statements....
Jacob
Unread 04-02-2007, 00:46
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
Re: Crazy Loops
well this might be wrong but isnt the operator control function called from one big while loop in main?
you might want to put all of that in a function then in opcon do a
int i = 0;
while(1)
if i ==0
function();
i++;
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 04-02-2007, 00:49
dpick1055's Avatar
dpick1055 dpick1055 is offline
David Pick
FRC #1739 (Chicago Knights)
dpick1055 is on a distinguished road
Send a message via AIM to dpick1055
Re: Crazy Loops
While I have never worked in Easy C my best guess would be that it needs some sort of end while statement. While it doesn't seem likely cause C doesn't have a end while command I know it is in other languages so it's worth a shot. Good luck getting that working.
Always remember to take your powered wheels off the ground when first testing code. Otherwise you'll end up with holes in the wall like us
Unread 04-02-2007, 00:52
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
Re: Crazy Loops
GetTimer returns an unsigned long. Your timer variable is an int.
Does that make a difference?
Unread 04-02-2007, 00:55
AKA: Jacob Komar
Re: Crazy Loops
Whats weird, is that using the Wait block works. Just replacing the while loop with this block works. This is inconvenient though, because if you want to do anything with this time, you can't.
Perhaps it is the enclosing loop... I'll try this.
Thanks,
Jacob
Unread 04-02-2007, 00:58
Eric Finn's Avatar
Eric Finn Eric Finn is offline
FRC #0166 (Chop Shop)
Eric Finn has a spectacular aura aboutEric Finn has a spectacular aura about
Send a message via AIM to Eric Finn
Re: Crazy Loops
Do while 1, and have an if statement in your while loop, something like
if(!(timer < 20000))
break;
to break out of the loop
It always takes longer than you expect, even when you take into account Hofstadter's Law.
--Hofstadter's Law
Unread 04-02-2007, 00:59
AKA: Jacob Komar
Re: Crazy Loops
Mmmmm.... About the unsigned long...
It was correct in my real code... I remember changing that. Sorry my sudo wasn't updated.
Whats weird is that it wasn't the timer. I used the timer to change another variable from a 0 to a 1, which was a change you could see with a print statement. The while loop simply said while(done ==0) { yadda yadda }
and you would see done change from 0 to 1 without leaving the loop....
It's just bizzare.
Jacob
Unread 04-02-2007, 01:00
AKA: Jacob Komar
Re: Crazy Loops
break;
Yeah...... I forgot about break. Thanks for the idea!!!
Jacob
Unread 04-02-2007, 01:06
mluckham's Avatar
Re: Crazy Loops
If your 'done' variable was changing by itself, then perhaps the gyro call is assigning a variable of the wrong type ... if that variable is immediately adjacent in memory to the 'done' variable, the overflow would affect it.
This normally wouldn't be possible with a compiler like EasyC, which doesn't use pointers (well, it doesn't let US use pointers).
Please post the exact code - C code preferrably.
Mike
BTW - PSEUDO-CODE, not SUDO (but probably you know that)
Unread 04-02-2007, 01:11
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Re: Crazy Loops
Just so you know, it's pseudo code.
Unread 04-02-2007, 01:13
AKA: Jacob Komar
Re: Crazy Loops
Yeah... This would make sense. Althought printing out the value of done yielded 1.
lol yeah... Sudo is sudo for pseudo... hence sudo (my aim at a joke... perhaps a few hours of sleep would be more humorous to my team members...) OK that was pretty lame. I'll go back to using pseudo.
Unread 04-02-2007, 01:28
mluckham's Avatar
Re: Crazy Loops
Looking only a pseodo-code can lead one to erroneous results.
I once worked on a project where every module was coded, and had to have COMPLETE pseudo-code in the file header as well. Endless hours were spent making sure the two lined up.
Of course the programmers only looked at the code, knowing the pseudo-code would sometimes be wrong.
Recently I had a variable that mysteriously changed values, in a loop like yours. This was using MPLAB. Turned out there were two variables with exactly the same name, one in local scope and one in global scope. The compiler never hinted of the conflict (well, that's my story and I'm sticking to it!). Of course the global one was being updated (by an external .C routine) and the local one was read by the printf ... since it was on the stack and there were interrupts in the system, it always contained garbage.
Unread 04-02-2007, 11:05
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Re: Crazy Loops
The operator control routine in EasyC is run and run and run. If you exit, it will just call it again for you. To stop that behavior add something like the following to the end after the print done.
while (1) ;
Unread 04-02-2007, 11:17
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
Re: Crazy Loops
i dunno much about easyC, but in MPlab, while loops are never a good thing. They have a tendency to cause the motors not to get data. If that's not the case in EasyC, then ignore me. Otherwise, use if statements
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 04-02-2007, 11:32
AKA: Bud
Re: Crazy Loops
Thats not the case in EasyC - EasyC documentation indicates Getdata and Putdata is done in the background automatically for you.
While loops Guy_E VEX 6 01-11-2006 22:04
POLL: control loops Rickertsen2 Programming 2 28-10-2004 20:32
loops inside of subs??? manodrum Programming 4 19-02-2003 20:05
Solution to Timing Loops Steven Carmain Programming 39 10-02-2003 13:33
Programming Loops Mike o. Programming 5 26-03-2002 11:24
