Go to Post Tragedies happened. We've learned from them, as individuals, as teams, as a community. - Taylor [more]
Unread 04-02-2007, 06:17
Joel J's Avatar
Joel J Joel J is offline
do you..
Re: Wire recommendations
Joel,
MCM electronics has a variety of wire. (www.mcminone.com) We use the "zip" wire that is paired red and black wires bonded together. They can be separated by "zipping" them apart. I suggest #10 for all high current motors regardless of what breakers you use.
We use Anderson Powerpole connectors when needed. They are available in a variety of colors and can snap together to form multi contact connectors. You can purchase them through Terminal Supply or West Mountain Radio. At West Mountain you can also purchase a really good crimper for these contacts.
I also recommend you position the Victors close to the motors so you don't have to add a connector in series with the motor leads. Then you cut to fit the wiring from the breaker panel to the Victor and use the existing motor wire to the Victor. We use a bent pushon male adapter with a screw mounting hole. These are available from Digikey. We add them to both sides of the Victor and then use normal pushon females for connections. This allows us to swap out a motor or controller that has failed without tools.
The house wire suggested before is also available at most home centers like Menards or Home Depot and you can buy it by the foot.
Hi,
What do these pushons look like (the old network connectors?)? Is "male push on" the actual name of this adapter? I tried a search on Digi-key, but it turned up nothing as a result.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Sensor Recommendations Workaphobia Programming 9 20-01-2005 13:45
Joystick Recommendations Travis Hoffman Electrical 12 18-01-2003 18:04
Brecoflex recommendations D. Gregory Technical Discussion 3 13-01-2003 11:10
Timing Belt Recommendations? Eric Reed Technical Discussion 1 10-01-2002 00:25
Tooling recommendations SiliconKnight Technical Discussion 1 19-12-2001 22:03
