Go to Post I'm glad to be on the same team as smart people. - Andy Baker [more]
Unread 04-02-2007, 01:25
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
RC Secret Key Sequences
Does anyone remember the problem the RCs had a few years back where you could not get out of programming mode anymore? There was some key sequence to fix this, does anyone remember it?
Also, wasn't there one that would make your LEDs flash in rainbow colors? Are there any other ones beside that?
Thanks!
Unread 04-02-2007, 07:56
nparikh's Avatar
nparikh nparikh is offline
i heart infrared
AKA: Neil Parikh
FRC #0025 (Raider Robotix)
nparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond repute
Send a message via AIM to nparikh Send a message via MSN to nparikh
Re: RC Secret Key Sequences
We'd love to get the one for getting it out of program mode! Our 2005 RC is stuck in program, and it would be pretty awesome if we could get that to work .
Doing the right thing is always better than doing the easy thing.
Team 25 Alumnus
Attending: NJ Regional, Boston Regional, the Championship Event
Unread 04-02-2007, 09:42
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Thanks!
As for the first question, I had to deal with that this year. Hold reset and program when you power on, then let off of reset but keep holding program for a few seconds, then let off program and tap reset. The controller should be back to normal. I don't know of any other sequences, but I'm sure there has to be at least one more.
BTW, it's in the IFI FAQ: lemme find the link...
EDIT: Found it: http://www.ifirobotics.com/forum/vie....php?p=338#338
JBot
Aren't signatures a bit outdated?
Unread 04-02-2007, 10:21
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
JBot
This sequence doesn't always work for a stubborn RC. We tried it several times, and each time after tapping reset the program light would go green for about three seconds and then go orange again. We ended up having to reflash the RC with the master code and then hold down the program button while we downloaded new user code. In all, it took us about 30 minutes to troubleshoot. I know I was doing the unstick-from-program-mode sequence correctly, because our on our '06 RC it happens quite frequently, but our '07 RC just doesn't care. It's a real pain.
Does anyone know the causes of the stay-in-program-mode bug?
Thanks in advance,
Robinson
Unread 04-02-2007, 11:52
I encountered one a couple of years ago that was due to an almost invisible sliver of aluminum physically grounding the PROG pin on the three-pin connector.
Unread 04-02-2007, 12:47
esquared's Avatar
esquared esquared is offline
Keeps saying 3-2-1-Rush...
AKA: Angry Eric
no team (Volunteer!)
Team Role: Mascot
esquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond repute
We had this problem about a week ago. Possibly the problem is that the program you downloaded was interrupted/severely broken. Symptoms include not being "stuck" in programming mode if you aren't tethered/radio modem connected, and you can press the button and send it into program mode. The RC is in a bizzare state of running but not running, where the watchdog LED (Code error) won't turn on. We resolved the issue by swapping laptops, and found we were having a problem with the serial port.
Otherwise, look for the sliver like A.A. suggested.
Unread 04-02-2007, 13:44
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
Funny this should come up. Yesterday our RC went into Knight Rider mode and pulsed the green and red LEDs up and down until we hit the reset button. We're not really sure what caused it, but it sure looked cool, despite causing panic in the shop.
Unread 04-02-2007, 16:02
esquared's Avatar
AKA: Angry Eric
Team Role: Mascot
http://www.ifirobotics.com/forum/vie...ght=diagnostic
That's what caused Knight Rider.
Unread 04-02-2007, 19:01
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
That happened to me on the 2004 RC. See Christmas Tree Lights On The Controller for that incident. (See also: Does your RC do this?)
I have thought about getting the OI to do this to indicate something's wrong, but I haven't done it, yet.
Unread 05-02-2007, 07:16
Thanks for the info, guys!
Hex vs. Key alysume Technical Discussion 12 31-05-2006 22:37
Is defense Key? ThomasH Championship Event 6 29-04-2006 15:48
A Secret Team75electric Off-Season Events 4 06-06-2005 18:14
2 mm key stock Andrew Technical Discussion 8 03-02-2003 22:29
Traction is Key >^..^< archiver 2001 0 24-06-2002 02:37
