Re: BaneBots 56mm Gearbox - Second Stage Sun Seizing
It sounds like maybe you are putting too much side load on the output shaft. Is the shaft solidly supported at the other side of the load (load = sprocket, wheel, etc)?
Re: BaneBots Gearbox Locking UP
Yes, we're useing the matching bearing block.
Hrm. I was having a similar issue with one of my gearboxes this week while installing a new carrier. It was binding at a particular angle and it seemed like the shaft was forcing the sun gear to be off center in the planetaries. The solution (which I can only semi-jokingly recommend) was to find the position of most binding, lay the flat spot of the sun gear on a vice, and tap the bearing block gently with a hammer to try to force the end of the shaft to bend slightly in the opposite direction. It seemed to work, but it may have been all in my head.
Getting the alignment perfect on these gearboxes is a tough but worthwhile adventure. I reassembled two this week: one went together with no problems at all and drew less than 2.5 amps. The other had alignment issues, most caused by my new carrier plate, and originally drew over 4 amps. But after breaking it in, tearing it down, polishing the bearing block to make it a better fit into the ring gear housing, and reassembling, it is now also down to 2.5 amps and sounds a lot happier. |
What purpose does it serve to have the sun ride on the output shaft? On the first stage, the sun is not supported, nor are any of the stages in the 42mm 64:1 gearbox.
In the first stage, the sun gear is supported by the motor. You're right about the lack of sun gear support in the center stage of the 3 stage boxes. Although the sun gear in any of the stages after first is somewhat supported by the planet carrier that drives it.
You could probably get by without the support for the sun gear on the final stage, but you might want to take it apart and check the wear pretty often....then again, you might want to take it apart and check for wear (and add new grease) pretty often no matter what you do! The upside is that they're fun to take apart and play with. |
We had a similar problem this weekend and after a complete teardown of the tranny, discovered WHAT the problem was.
What we discovered was that TILTING the tranny (or the robot for that matter) may cause one of the planetary gears to slide down the pin it is mounted on and get JAMMED between the ring that is used to mount the tranny to the adapter (the one with the 6 little allen key screws). This does NOT happen everytime you tilt the tranny, only if the planetary gear happens to stop in the right spot (not sure what the tolerance on getting "lucky" is). I wish I had the pictures we took, am working on that now. We have our lead mechanical working on creating a spacer to put between the planetary gears and the 2-stage gear to prevent any of the planetary gears from dropping down and jamming. Other than a spacer of some type, not sure if there is any other solution. I am also not certain if BaneBots or FIRST is aware of this second issue (it ONLY affects the 2 CIM adapter). You can certainly NOT guarantee that your robot will not tip over :-( As soon as I can get the pictures, will post them. |
#7
I don't see any reason to have the output shaft go through the sun for stage 2. It may help allign things but I believe that every thing should work without it.
One thing that caught my eye in you post is that the shafts siezed and/or scored. I wonder if the chaft was not smooth to begin with? It is possible that is part of the problem. Also, it is possible that somehow the surface did not get greased properly. On another note, WaterFreak brings up a very good point. Looking at the parts, I can definitely see that the tabs on the 2-CIM adaptor can cause a jam if one of the planets gets up in the space between the tabs. One easy fix may be to put a spacer on the cluster gear (over the sun but below the big gear). Here are some washers from McMaster that may work well for this purpose: 98038A268 The ID just fit over the sun and its OD is 1.3" will hold the planets out of the space. I would recommend using another washer below it to keep it spaced out right. If 2 washers work fine, but it looks like the spec as 2 washers being just a bit too thick (we need to space it out by .220" or so and each washer is 0.122-177" too think for 2). I think this wave washer may be just the ticket: 92161A035 I have to call Ed from Banebots on another matter. I will make sure that Banebots is aware of this issue. UPDATE: I was just talking to Ed, explaining the problem when I thought, "Hey, wait, isn't there a washer or wearplate already IN that gearbox that would prevent the planets from dropping?" I had done my initial evaluation using a naked carrier, not a whole gearbox assembly. Investigations showed that, yes, there is a washer/wear plate in the gearbox. It may have been stuck up to the aluminum motor mounting plate, but it is there. You can even see it in Banebot's excellent instructions "...Once removed, the back plate wil slide off. Make sure that the thin metal separation plate stays with the planetary gearbox as shown" FYI Joe J. Last edited by Joe Johnson : 05-02-2007 at 13:39. |
#8
Just looked at the assembly instructions, I can say for certain that neither of our assembled transmissions has that spacer plate in it.
I will have to check when I get to our meeting tonight if they are with the "extra" parts from when the transmissions were taken apart to assemble into the 2-1 kit. Am wonder if that spacer plate is getting stuck to the block you remove and we just did not notice it. Just a suggestion to pass along....In the assembly instructions, it might be a good idea to make a bigger thing of making sure that spacer is present. The wording is at the end of a small paragraph and might get easily overlooked. Seperating it out into its own bullet would make it harder to miss. |
#9
On the transmission I took apart, the black wear plate was well stuck (with grease) to the motor end aluminum block, and it would be very easy to overlook the fact that it's a separate part, and needed with the new block.
#10
Good thing for all the team using the 2-motor adapter to make sure of, otherwise any tippage of the transmission/motor abbembly OR of the robot (say when you might fall off a ramp???) might then lead to a seized motor ![]() |
#11
There have been a few creditable reports of this S4 problem (S4 = Second Stage Sun Seizing).
Here is another one: http://www.chiefdelphi.com/forums/sh...3&postcount=79 I don't yet know how much of a problem this is going to be but this is what I recommend to teams: Take apart your Banebot 56mm gearbox and inspect it.
More to come. Stay tuned. Joe J. Last edited by Joe Johnson : 09-02-2007 at 15:00. |
#12
how would we get the siezed sun gear off?
#13
Can you post a photo of how the bearing block is mounted? If it is not fully supported then it isn't going to do much good.
Another problem may be that the lubrication at the pinion/shaft area where you are having problems is probably not as good as it should be, maybe you need to take the gearboxes apart and lubricate them kind of often? |
#14
2xCIM at 16:1... Wow! That's a LOT of torque. (And stress... both on the gearbox and the team until this double-d thing gets worked out.)
I can't say for sure we experienced the same thing as we are just using 12:1 trannies with one CIM, but we had some similar "lock up" symptoms and shortened the spacer on the motor shaft and ground down the end of the motor shaft about .10" and everything started to move a lot more freely. There are some great suggestions towards the end of the "Double-D Reloaded" thread, as well as a .pdf near the bottom of the 56mm tranny page on the Banebots site that can explain this more clearly. However your symptoms sound slightly different from ours (we had a lot of wear on the end of the CIM where the gearbox pushed the spacer against the motor) so if you have already shortened the spacer and are still getting this lockup problem... my apologies for posting a non-solution. Jason |
| Banebot 56mm gearbox - double D - V3 - It's Show Time. | Joe Johnson | Motors | 34 | 18-02-2007 19:00 |
| Banebot 56mm gearbox - double D - RELOADED | Joe Johnson | Motors | 82 | 09-02-2007 14:07 |
| New Banebots 56mm transmissions for sale | fsracer | Motors | 1 | 07-02-2007 22:58 |
| Banebot 56mm gearbox - double D related | Joe Johnson | Motors | 78 | 31-01-2007 23:55 |
| 56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? | VEN | Technical Discussion | 4 | 11-01-2007 14:45 |
