Go to Post You know you're addicted to FIRST when robots are sexy! - Pat Arnold [more]
Unread 04-02-2007, 13:27
bobpskier bobpskier is offline
FRC #0159 (Alpine Robotics)
bobpskier is an unknown quantity at this point
Setting Dashboard UserBytes
Is it possible to set the UserBytes sent via the OI's dashboard port using EasyC Pro? It looks like we can set LEDs and the UserDisplay on the OI. I have not seen any API that gives us control over the userbytes.
We'd like to send some additional data through the dashboard port. Using MPLab we could set these userbytes. This year we've been working in EasyC Pro. We are trying to integrate some additional data to be displayed in LabView via the dashboard port.
Thanks,
Bob Potterveld
Unread 04-02-2007, 22:57
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Setting Dashboard UserBytes
Yes you can write to the dashboard in easyC PRO. The command is
SetUserByte(unsigned char index, unsigned char value);
Example:
unsigned char value;
value = 52;
SetUserByte(6, value);
Unread 05-02-2007, 21:36
Thanks for the info. Once we upgraded to EasyC Pro version 3.0.1.1 we were able to link properly using the function SetUserByte(). Apparently the 3.0.0.1 version did not contain this function to link against.
Thanks,
Bob Potterveld
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 02:04
setting camera sbwprotoss9 Technical Discussion 0 17-01-2006 21:05
2004 Dashboard Protocal vs 2005 Dashboard Protocal Kyle T Programming 4 14-03-2005 22:19
Setting up Apache2... Mike AA Website Design/Showcase 7 08-06-2004 19:18
Setting up a webcam D.J. Fluck Chit-Chat 1 08-09-2003 01:32
