Go to Post Our "gracious professionalism" credo insists that we make decisions that are based solely on the desire to inspire and recognize science and technology using robot construction and competition as a vehicle. - Al Skierkiewicz [more]
Unread 04-02-2007, 15:00
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
do we "NEED" the power distribution block
does the rules require us to use it or is it optional. because personally i see it as a waste of space and weight.
Unread 04-02-2007, 15:02
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: do we "NEED" the power distribution block
We all do. But, it is required, and you will not pass inspection without it.
Unread 04-02-2007, 15:07
seanl's Avatar
yay time to rewire.
Unread 04-02-2007, 17:08
yay time to rewire.
Please check the Tips and Guidelines for instructions on how to wire this critical part.
Unread 04-02-2007, 23:09
foote stepped in
AKA: E. Foote
FRC #0868
do we "need" it? I'd say not; I can't see how it's application is remotely close to a robotics competition, where weight is a major factor in it.
But, since the rules are the rules, yes, you must have it in your robot. so you do "need" it.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 05-02-2007, 01:50
CardcaptorRLH85's Avatar
CardcaptorRLH85 CardcaptorRLH85 is offline
The master of the cards ^_^
AKA: Raa'Shaun H.
FRC #0322 (F.I.R.E. "Flint Inspires Real Engineers")
CardcaptorRLH85 is an unknown quantity at this point
Send a message via ICQ to CardcaptorRLH85 Send a message via AIM to CardcaptorRLH85 Send a message via MSN to CardcaptorRLH85 Send a message via Yahoo to CardcaptorRLH85
I have a question about that power block. Does it add any type of safety advantage? I'd hope that FIRST wouldn't purposely add required weight without cause. I'm only asking because I truly can't see the advantage of having it over not having it.
Unread 05-02-2007, 07:51
Although I wasn't part of the process, I can't answer for First. However, this type of block is in constant use in the electrical industry and is quickly becoming a system desired by many Electrical Engineers. In addition to the blocks which you are now familiar with, relays, timers, circuit breakers (even 3 phase and motorized trip) computer interface, power supplies, etc. are all becoming available for use with the DIN mounting rail system. Other then the added weight and larger size than the IFI panel (which was a perfect match for our robots) this panel may make it easier for rookies to get wired up with a minimum amount of tools.
Unread 05-02-2007, 10:41
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Here's my view on this:
Is it an improvement on the IFI panel? Definitely not. That was a nearly perfect for our robots and its a shame to not be able to use it.
However, I would say it is an improvement over the 2k4 system - as it adds the ability to ground the 40A motors to something other than the FASTON connectors on flimsy 20/30A block, and allows you to eliminate the FASTON's from the high current motors (we use Anderson Powerpoles everywhere instead). It also eliminates the "stacking" of ring terminals for the 6ga connections that could be more likely to cause intermittent connections (as multiple ring terminals on a single stud means more possibilities of moving wires, more likely that the nut will loosen). The weight is annoying - but not as annoying as the 40A MAXI block. It also removes more 6ga ring terminals from the system and replaces them with simple set screw system, which is easier to terminate correctly than a large crimped ring terminal.
But oh well, we have to live with it.
My posts represent my personal views only, and do not represent the views of either my team, Team 190, nor its primary sponsor, Worcester Polytechnic Institute.
Unread 05-02-2007, 14:03
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
Has anyone found a distributor for the Rockwell Block?
Personally, I am trying to give this thing the benefit of the doubt. I, like everyone, I guess, preferred the 2005 all-in-one solution, but we gotta roll with what first gives us.
One quick note - we have discovered that it's easy to think that you have the 6 AWG wires in place without actually having a solid connection, so be sure to open the screw up all the way, and to give the wires a serious tug after you screw them down. Otherwise, you might see battery wires heating up, and large voltage drops with high current draws.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 05-02-2007, 14:28
Our local Rockwell Automation distributor does not have any in stock. Minimum order of each item is 50.
If somebody could find a distributor that stocks them, that'd be great. Otherwise we might try to pool an order.
Unread 05-02-2007, 20:55
youngWilliam14's Avatar
youngWilliam14 youngWilliam14 is offline
Team 461 Electrician and Operator
AKA: Will Crabtree
Team Role: Electrical
youngWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud ofyoungWilliam14 has much to be proud of
Send a message via AIM to youngWilliam14
I'd just like to know one thing: are we allowed to cut the yellow jumpers to fit just two or three blocks? I'd love to get rid of the red and black blocks that I won't be using.
"C.N.C." lyrics/"Driving on Regolith" lyrics
Let's all go nuts! Robots! Robots!--Team 461 chant
Unread 05-02-2007, 21:00
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
According to FIRST's answer in the Q&A, I would say yes.
Unread 05-02-2007, 22:18
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Be very careful cutting the jumpers. I would advise against it.
They sell jumpers for two blocks - I was told at a Bradley dealer, I did not order them however.
Mike Martus
Unread 06-02-2007, 07:36
William and Mike,
I don't think that the Q&A fully addressed the cutting of the jumper plugs. If that is allowed in the future, it must include a note to fully insulate the cut end. Quite frankly, the majority of weight is already there, and having an extra block to add functionality later would be a desirable thing. If you are using a four motor drive and 40 amp breakers, you need at least two red and three black blocks anyway.
Unread 06-02-2007, 08:51
Carpe diem
By my possibly wrong interpretation, by virtue of telling us we don't have to use all the blocks FIRST is telling us we can cut the yellow jumper. The yellow jumper will not fit if you do not cut it. I would assume the person answering the Q/A would know this. You know what they say about assuming...
I will make sure the teams I mentor add a strip of electrical tape on the metal exposed end of the jumper.
Power Distribution Block Grounding Karma Electrical 15 22-01-2008 07:18
Question:Power Distribution Block Pavan Dave Electrical 35 20-03-2007 20:10
Power distribution Block? Pontchartrain Electrical 3 27-01-2006 07:30
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
Power Distribution Block DukesElectrical General Forum 0 09-02-2004 23:48
