Go to Post Your team has a cave?!?!? OMG, how did you guys get that?!?! Do you have a cave sponsor? We tried talking to cave sponsors but none of them responded. You guys must be an elite team to have a cave. - marshall [more]
Unread 04-02-2007, 15:44
enpurx's Avatar
enpurx enpurx is offline
ChiefDelphi Addict
AKA: Rachel
FRC #2022 (IDK)
enpurx will become famous soon enoughenpurx will become famous soon enough
Send a message via AIM to enpurx
Norgen Relief Valve
Our teams Relief valve is leaking at low PSI. What is the proper assembly for the relief valve?
Unread 04-02-2007, 16:11
dtengineering's Avatar
AKA: Jason Brett
Re: Norgen Relief Valve
The relief valves are adjustable. There is a double-nut system to keep them tight, so first (with NO PRESSURE on the system...) release the thin inner lock nut, then tighten the larger, outer cap to increase the release pressure.
Give it a test. You should have it set to release at about 120 psi. If you go above 120 psi loosen it off, if it lets go before 120, tighten it up. (I like to do these adjustments with the system depressured.)
When you get it set to 120, then tighten up the lock nut snug to the cap.
Check it again... and you should be good to go.
Jason
Unread 04-02-2007, 18:16
enpurx's Avatar
ChiefDelphi Addict
AKA: Rachel
FRC #2022 (IDK)
Thank you I hadn't realized that, its helping but it still seems to be leaking, is the valve supposed to be assembled pointed piece>spring holder>spring>then finally end cap? I think the reason it may be leaking is because A. its assembled wrong, or B. there is dirt pushing that pointed piece up from the hole... Does this seem like reasonable possibilites, and did I assemble the valve right?
Unread 04-02-2007, 19:24
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Not sure I understand how you connected it, but here's what the pneumatics manual says:
Originally Posted by 2007 FRC Pneumatics Manua
Look at the top of the regulator. You will note that one port extends out a little bit more than the others. It
also has an arrow on it to denote the outlet of the regulator. The opposite port is the inlet. A pressure gauge may
be placed in either of the other ports. You will have to plug the other gauge port with the enclosed hex plug.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 04-02-2007, 20:58
Electrical Engineer
Rookie Year: 1995
Jason
Jason,
Please read rule <R102>.
The wording is archaic as years ago the valve was pre-installed on the compressor. However, the valve comes pre-adjusted and should not be tampered with.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 09-02-2007, 13:51
Ralph Lambert Ralph Lambert is offline
Mentor - Team 1094
None #1094 (Channel Cats)
Ralph Lambert will become famous soon enoughRalph Lambert will become famous soon enough
The relief valve parts were loose when the bag was open so one of our students took the end of the valve off and apparently put it back together again. I later found a small brass disc on the floor and they said that they recognized it. Is there an exploded view of this valve anywhere? I am not sure we have all the parts or if they are all back where they belong.
Unread 09-02-2007, 14:04
Electrical Engineer
Rookie Year: 1995
I would contact FIRST and ask for a replacement.
Mike Betts
Unread 12-02-2007, 03:50
nsr's Avatar
nsr nsr is offline
nitroussuprarola
AKA: Ryan G.
FRC #2090 (P.E.T.T.)
nsr is on a distinguished road
Send a message via AIM to nsr Send a message via MSN to nsr
hmm, well today when i worked on our pnuematics we encountered difficulties with the valve and had to take about 4 hours just to find leaks in the pnuematic system and put teflon on all of our brass plugs and everything else that seemed to be leaking.
i would check to see if any other part of the pnuematics system is leaking before you try to ask for a replacement or anything... make sure that it's the part that isn't working.
good luck
Unread 06-02-2008, 19:44
Redbull2486 Redbull2486 is offline
FRC #2012
Redbull2486 is an unknown quantity at this point
just a question do you have to mount the relief valve on a certain side of the compressor
Unread 07-02-2008, 22:32
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC &amp;amp; FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Until this morning I would have said no. However, the discussion and ruling in the GDC Q&A in this thread says yes.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
where do i place the norgen relief valve? Reaper40 Pneumatics 1 25-01-2007 18:25
Where do we get a relief valve? P1d40n3 Pneumatics 4 17-01-2007 10:04
Need the number for the Norgren Pressure relief valve Jack21 Pneumatics 0 23-01-2004 16:32
Relief... Joel J General Forum 0 31-05-2001 17:07
