Go to Post Just remember to be as transparent and inclusive as you can. - DonRotolo [more]
Unread 04-02-2007, 08:14
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
pic: Mmm ... Greasy Worms :-P
Unread 04-02-2007, 08:16
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Re: pic: Mmm ... Greasy Worms :-P
well we don't use the worms, but we do use the shnazzy pvc spacers. Do you have any other pics of this drivetrain? I would like to see why you are using a worm gear.
Unread 04-02-2007, 09:53
Barry Bonzack's Avatar
Barry Bonzack Barry Bonzack is offline
Impossible to rain on my parade.
FRC #1902 (Exploding Bacon)
Barry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond repute
Send a message via AIM to Barry Bonzack
Would this be because the gears won't backdrive when you are being pushed, so your wheels will lock up?
Chair of Florida FIRST Alumni
Orlando Regional Planning Committee
FIRST Tech Challenge Florida Leadership Team
Program Planner on the Orion Spacecraft at the Kennedy Space Center
Twitter: @FL_FIRST_Alumni
Events I'm Emceeing/Game Announcing:
1/10/2015 FTC Jacksonville League Championship
1/11/2015 FTC Central FL Tesla League Championship
1/17/2015 FTC South Florida League Championship
1/24/2015 FTC Tampa/St. Pete League Championship
2/7/2015 FLL Orlando Regional
2/14/2015 FTC State Championship
2/26-2/28/15 FRC South Florida Regional
3/8/2015 FLL State Championship
3/12-3/14/15 FRC Orlando Regional
4/22-4/25/15 FIRST World Championship Event - FTC Franklin Field
Unread 04-02-2007, 10:07
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
are you using a copper worm gear? is the gear that the worm gear mates to copper?
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 04-02-2007, 11:22
Andrew Blair's Avatar
FRC #0306 (CRT)
Nah, worm mating gears are almost exclusively bronze or brass, in order to permit the two gears to mush together a bit, creating a smoother running setup with less backlash.
-Sir Francis Bacon
-Albert Einstein
Unread 04-02-2007, 12:32
Tim Delles's Avatar
Since 2001.
FRC #0078
That is what it is. I for some reason thought that they were made out of copper, but now that you say brass or bronze it all clicked.
Just to warn you, that these 2 metals are relatively soft. If to much force is exertaded onto them, it will strip the 2 gears.
This is our gearbox for our wings in 2003. However we started noticing severe wear at our first regional. By the time we got to nationals we new that it was pretty well gone. The brass gear that you can be seen (the gear that is cut to only 1/4 of a gear) was completely stripped.
Now i haven't thought about it in so long, and i don't know the exact force that was working against the gear, but im pretty sure that it is less than some robot will be pushing against you with.
Hopefully you thought it all out before deciding to do a worm gearbox.
Good luck and let me know how it turns out
Unread 04-02-2007, 13:37
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The small gear is steel, the large gear is bronze. This is a good way to make a worm gear system, I would not worry about it. And the grease is another sign that they know what they're doing....
Unread 04-02-2007, 14:53
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
That grease won't help them if they collide with another robot at high speed... I remember from 2004 and prior about people using the drill motors with their gearboxes, without removing the anti-backdrive pins, and completely destroying the internals during impact with other teams.
I would at the very least look into the fact that there may be a problem down the line, and ways to fix it, if I were them.
2001-2004: Team 100
2006-Present: Team 254
Unread 04-02-2007, 15:57
Jared Russell's Avatar
Taking a year (mostly) off
The red grease makes it look like a meat grinder. Which I happen to think is really cool
Unread 04-02-2007, 16:23
GVDrummer's Avatar
GVDrummer GVDrummer is offline
AKA: Jake Hall
FRC #0216 (RoboDawgs OTL)
GVDrummer is on a distinguished road
Send a message via AIM to GVDrummer
I would have to agree
Unread 04-02-2007, 17:27
Jeffrafa's Avatar
Robotics Addict
AKA: Jeff Lewis
As far as worm gears go, its a relatively low reduction. We used a quad-thread worm - which really makes it roughly halfway to a helical gear set. This means it is backdrivable, but is notably more resistant than standard gearing. Also the quads appear to be able to take greater stresses than comparable single or double threaded worm gears, although I don't particularly know why.
It is a bronze worm gear with a hardened steel worm, as mentioned in previous posts.
I have checked the numbers as best I can and I think they'll hold up to the abuse that the robot is bound to see, but we'll be running them in and doing some heavy testing in the next week or so to see how they hold up. The biggest unknown is the shock loading like Cory mentioned, so this will be something we will test for. There is still room for some changes if they don't seem to be holding up well enough - but for now we'll just keep those in our back pocket until the need arises.
Unread 05-02-2007, 20:48
angelc24's Avatar
angelc24 angelc24 is offline
A Pirate's Life For Me...
AKA: Christina
FRC #0467 (Duct Tape Bandits)
angelc24 has a spectacular aura aboutangelc24 has a spectacular aura aboutangelc24 has a spectacular aura about
Send a message via AIM to angelc24
Just to warn you- in the past we've had difficulty turning with worm gears.
The meat grinder effect is really cool though.
"You need people of intelligence on this sort of mission....quest.....thing."
"Where did all the food go?"
"Ask the programmers."
"Whether a bot is made of new parts, old parts or spare parts, you can shine no matter what you're made of"
2005 Delphi Driving Tomorrow's Technology Award
2006 Xerox Creativity Award
2006 Delphi Driving Tomorrow's Technology Award
2007 Johnson and Johnson Sportsmanship Award
2008 Judges' Award
Unread 28-04-2007, 20:43
Squirrel Lord's Avatar
Squirrel Lord Squirrel Lord is offline
Down, Down-Right, Right, Punch!
AKA: Alex Cohen
FRC #1425 (Error Code Xero)
Squirrel Lord will become famous soon enough
Send a message via AIM to Squirrel Lord
Your robot learned first hand that these worms worked in a high speed collision, thanks for the bumber by the way... I have got to get around to mounting it!
Teams: Mechanical, OI, Drive and Animation
Competitions Attended: Portland (Semifinals), San Diego (Quarter Finals), Las Vegas (Winners with 254 and 1983), Atlanta (Undefeated in Galileo qualifying, knocked out in first round of non-qualifying matches.)
Webcomic Status: Currently Working on site and art
Expected Arrival Date: Soon
Mmm... evulish Chit-Chat 9 17-09-2002 15:45
