Go to Post As I told my friend Joe Johnson, just because you aren't around as much doesn't mean that you can just close the book on this chapter, instead - just keep a book marker in this place, so you can remember how to find your way back home - when the time is right. - meaubry [more]
Unread 03-02-2007, 16:08
devaaki's Avatar
devaaki devaaki is offline
Rookie Captain
AKA: Jeff Lou
FRC #2052 (KnightKrawler)
devaaki is on a distinguished road
Pneumatics - what do we do with exhaust air?
Does exhaust air need to be muffled, or can it just be opened to the atmosphere?
Unread 03-02-2007, 17:08
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
Re: Pneumatics - what do we do with exhaust air?
just opened to the envirement.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 03-02-2007, 17:13
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
feeding it back in might pose problems, but if u put a compresser on the robot, just vent it
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 03-02-2007, 17:45
Tim Delles's Avatar
Since 2001.
FRC #0078
Either way the easist thing to do is to vent it.
Unread 03-02-2007, 23:41
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
(you could alwasy loop it back into your system so that minimium ammount of air is lost if you are not using a compressor)
The system won't work this way - air moves from higher pressure to lower pressure. If you vent the exhaust to a storage device, it will be at a slightly lower pressure than the cylinder you just used. If you keep venting more and more air, eventually you will equalize the system pressures and nothing will move.
Unless you want to work another downstream cylinder at a lower pressure, and set up an elaborate system of check valves and pressure reliefs, you can't get more work out of the exhaust.
Let them vent, and don't even worry about putting fittings on - save the weight.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 04-02-2007, 11:04
Tim Delles's Avatar
Since 2001.
FRC #0078
After I posted, i realized that you would need check valves, therefore making it much more complicated (and i do believe unusable since i don't think you can use check valves on the robot)
Unread 04-02-2007, 11:10
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
If you use the fittings with the little screw adjuster (flow control) you can affect the speed that a piston moves (somewhat) this can help in a situation where you want to slow down the piston if it is lifting something heavy while pushing but you want it to come back slower when pulling. Sorry don't have a good picture handy. Also not sure the flow control fittings are part of the kit this year.
Biff
Unread 04-02-2007, 14:02
AKA: Dr. Brooks
no team (WRRF)
Smile Re: Pneumatics - what do we do with exhaust air?
I am shocked and dismayed by all of these suggestions to vent
exhaust air to the atmosphere! Don't you guys and gals know
your environmental regulations? You have to recycle this exhaust
air properly as hazardous waste...
Eugene
Unread 04-02-2007, 14:25
Billfred's Avatar
Billfred Billfred is offline
Eugene
Agreed! Everybody knows that you get nauseated if you breathe too much of this stuff in too fast.
(Sorry, couldn't resist.)
Unread 04-02-2007, 14:45
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
The only thing the sintered mufflers do is quiet the exhaust air some and help keep dirt out of the valve when it's not exhausting. The dirt factor isn't such a big concern in the enviroment where FIRST robots are as it would be where the valves are used out in some industrial applications.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 04-02-2007, 16:26
GVDrummer's Avatar
GVDrummer GVDrummer is offline
AKA: Jake Hall
FRC #0216 (RoboDawgs OTL)
GVDrummer is on a distinguished road
Send a message via AIM to GVDrummer
I think you need to have a car muffler on their that makes it hum... lol
Unread 10-02-2007, 01:00
Kaizer007's Avatar
Kaizer007 Kaizer007 is offline
Hyped up on half and half, Mentor
AKA: Daniel
FRC #0498 (Cobra Commanders)
Kaizer007 is a jewel in the roughKaizer007 is a jewel in the roughKaizer007 is a jewel in the rough
Send a message via AIM to Kaizer007
If regular air is being inserted through the compressor into the tubing, stored and used to move a piston, then released out into the atmosphere, isn't it just the same air it was when it went in? Why would it be considered hazardous waste?
And I would like to know if team could and would post a diagram of a simple closed air system (or explain in Great detail) to feed compressed air back into a system instead of releasing it and losing air pressure. Our team never really got around to creating a sub pneumatics team. It's always been just Electrical, Programming, and Mechanical.
I would assume a second lower pressure system would be needed to feed into, but I don't know how to feed it back into the higher pressure system, or to keep them unequalized, or the effect a 60 - 40 PSI co-system would have on power to the cylinders we are using.
*I had trouble finding anything helpful on the internet, although I'm a terrible, but persistant searcher.*
Unread 10-02-2007, 11:24
devaaki's Avatar
Rookie Captain
AKA: Jeff Lou
Pretty sure we're not going to be venting the air into the system - we were just wondering if we needed to put any mufflers on the valve.... Guess not
Unread 10-02-2007, 11:30
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Two words: Whistle Tip
What to do with pneumatics in the off-season Gary Bonner Pneumatics 8 30-04-2006 18:29
How to make Pneumatics use less air sanddrag Pneumatics 1 16-02-2004 15:50
Where to get air muslce pneumatics? Adam Y. Pneumatics 5 27-12-2003 23:17
switch lever exhaust Jeff Rodriguez Pneumatics 8 07-12-2003 07:14
Pneumatics-Extra Air Tanks archiver 2001 2 24-06-2002 00:13
