Go to Post Once again, my schooling is interfering with my education. - Caleb Fulton [more]
Unread 04-02-2007, 15:26
LionMane250's Avatar
LionMane250 LionMane250 is offline
User
AKA: Cooper
FRC #0250 (The Dynamos)
Team Role: Driver
LionMane250 is an unknown quantity at this point
Ramp Materials
This is for those of you who are making & designing a robot with a ramp. What are you making it out of? What problems are you having with deploying the ramp with an arm? Without an arm?
Unread 04-02-2007, 15:51
MarsBOtkid MarsBOtkid is offline
FRC #1523
MarsBOtkid has a spectacular aura aboutMarsBOtkid has a spectacular aura aboutMarsBOtkid has a spectacular aura about
Post Re: Ramp Materials
Aluminum with some type of gripping device on top
Unread 04-02-2007, 17:12
burkechrs1 burkechrs1 is offline
AKA: Chris
FRC #0668 (The Apes of Wrath)
Team Role: Driver
burkechrs1 is a name known to allburkechrs1 is a name known to allburkechrs1 is a name known to allburkechrs1 is a name known to allburkechrs1 is a name known to allburkechrs1 is a name known to all
Send a message via AIM to burkechrs1
Re: Ramp Materials
carbon fiber panels. very lightweight and very strong. then we're putting a grippingmaterial over them for obvious reasons...
Unread 04-02-2007, 17:54
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Ramp Materials
We're planning on building the gripping material into the aluminum ramp....using a secret patented process.....
Unread 04-02-2007, 18:06
wingnut1705's Avatar
wingnut1705 wingnut1705 is offline
AKA: Kevin
FRC #0453 (Gears)
wingnut1705 is an unknown quantity at this point
Send a message via AIM to wingnut1705
Re: Ramp Materials
Our team is using panels that are a composite of aluminum, plastic and styrofoam. It holds up very well.
Unread 04-02-2007, 20:28
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Re: Ramp Materials
Aluminum extrusion frame (8020) and 8020 honeycomb paneling thats 1/8" thick (its just like cardboard but plastic)...and it is extremely light weight.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 05-02-2007, 00:14
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: Ramp Materials
Plastic storage shelves from Home Depot, with some aluminum to hold it together and grip material to distribute force and increase traction.
I'll tell you are problems when we actually test them.
Unread 06-02-2007, 17:05
Matt Gardner's Avatar
Matt Gardner Matt Gardner is offline
...shiny.
AKA: Basil Mook~Sang
FRC #2200 (MM Rambotics)
Matt Gardner is an unknown quantity at this point
Re: Ramp Materials
My team is VERY, VERY new, so any input from a veteran team would be appreciated. We have designed our ramp system, but do not know what material to build it out of. We have an aluminium fram completed but need a material to mount on it to support the robots we will lift. Weight is a slight issue, we have considered:
- Lexan
- 1/4 inch plywood
- Expanded Aluminium
- Expanded Steel
Any input on our ideas and especially NEW SUGGESTIONS would be wonderful, thanks...
---------------------matthew gardner--------------------------------------------------------------------
| Catapultam habeo. Nisi pecuniam omnem mihi dabris, ad caput tuum saxum immane mittam |
FIRST, Breathe. FIRST, Breathe. FIRST, Breathe. FIRST, FIRST. Crap.
Unread 06-02-2007, 17:56
AKA: Chris
Team Role: Driver
Re: Ramp Materials
Steel is a definate no, and lexan can get up there in weight as well. Aluminum can be heavy but you could also cheese it if need be. Plywood can be heavy too especially in sheets for a ramp. Your best bet if you can get it would probably be diamond plate. It isnt that heavy, and it's alos strong. We're using carbon fiber with honeycomb filling but that is a little pricey. If you have the money i say do that.
Unread 06-02-2007, 20:12
Hunter's Avatar
Hunter Hunter is offline
Wood is Good
AKA: Todd Willick
FRC #5184 (Titanics)
Hunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond reputeHunter has a reputation beyond repute
Re: Ramp Materials
- Lexan
- 1/4 inch plywood
- Expanded Steel
Plywood would probably be your best option, without the ability to purchase high priced composites or honey comb paneling, or fancy sheet metal working, plywood will provide your best strength and rigidity for the weight, and is very simple to work with. Typical softwood plywood has density per unit area around 13%-14% that of aluminum, and birch plywood around 23% that of aluminum. Because of the decreased density your moment of inertia about the thickness will be much greater for a similar weight and will provide much higher strength. Also plywood is dirt cheap when compared with aluminum so it will be much easier to keep spares on hand.
Unread 06-02-2007, 20:47
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Ramp Materials
1279 has used alumalite: https://www.harborsales.net/fullshee...Faced%20Panels
Light & easy to cut.
Unread 06-02-2007, 20:53
MattLi's Avatar
MattLi MattLi is offline
Scrawny Asian Kid
FRC #0245 (Adambots)
MattLi has a spectacular aura aboutMattLi has a spectacular aura about
Re: Ramp Materials
Using: A semicircircular wheel, a TON of aluminum fencing, and an axle (aluminum shaft).
Problems: Danger to robots (we don't know if will may capsize with two robots)
Per Ardua ad Astra-Through adversity to the stars.
~Royal Air Force
Unread 06-02-2007, 21:09
Po-ser's Avatar
Po-ser Po-ser is offline
AKA: Polina Danilyuk
FRC #0694 (Stuypulse)
Po-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud of
Send a message via AIM to Po-ser
Re: Ramp Materials
We're using carbon fiber for our ramps too--thin sheets with foam blocks sandwiched inbetween. We're only at the point where we're just about to mount them, though, and we're trying to figure out how many spares we'll need. Have you guys been playing around, seeing how much it takes to break them? It would be awesome to have some input.
And Matt Gardner, as for a suggestion for your team--like the others, I'd strongly consider using honeycomb (try going to mcmaster.com and type in "Aluminum Honecomb" into the search tab). It's not cheap, but it's very light for its strength (good enough to be used for floor panels in airplanes). There's also the added benefit of spending less time constructing the actual ramp, since it arrives at your lab all in one piece, and spending more time on the actuators.
Hope this helps.
Aim for the stars, land in Hawaii.
2003 - NYC Regional winner
2005 - NYC Regional Woodie Flowers Award
NYC Regional Chairman's Award
Championship Galileo Division semifinalist
Unread 06-02-2007, 23:30
Uncrash's Avatar
Uncrash Uncrash is offline
The People's Hero
AKA: Jake Augunas
FRC #1276 (Kaizen Blitz)
Team Role: Communications
Uncrash is an unknown quantity at this point
Re: Ramp Materials
My first response would be to say aluminum angle and lexan, with cross supports underneath.
However, everyone is suggesting these new-fangled sandwiched materials. I'd suggest going with these, as I think thats what our ramp is being made from.
I'm pretty sure we got a few of our crew to go pillage the space shuttle, because whatever we found is some crazy stuff...
2006 - BAE Granite State Regional Champions
2006 - BAE Granite State Regional Team Spirit Award
Mathematics is the language of the universe.
The Written Word is the language of the people.
Learn both and you will be wise beyond compare.
Unread 07-02-2007, 08:57
AChastain's Avatar
AChastain AChastain is offline
FRC #0234 (Cyber Blue)
AChastain will become famous soon enoughAChastain will become famous soon enough
Re: Ramp Materials
I would look into corrugated plastic if...when weight becomes an issue. As long as you provide some support around it's edges to prevent bending, it has potential to work.
"Thirty bucks says the blue guy wins."
"You On!"
- bystanders, MEGAS XLR
Motor Ramp Up/Ramp Down Function Tom Bottiglieri Programming 12 03-12-2006 23:31
To ramp, or not to ramp? phrontist Rules/Strategy 27 26-01-2006 17:56
Materials stinger 3D Animation and Competition 3 26-02-2005 17:47
Materials Jeff K. General Forum 11 22-01-2005 02:24
Materials Finch Rules/Strategy 2 28-01-2002 23:00
