Go to Post Introverts can be good leaders too, we just lead differently. - Ari423 [more]
Unread 17-01-2007, 08:48
Benyamene's Avatar
Benyamene Benyamene is offline
FRC #2168 (Cyber Falcon)
Team Role: Student
Benyamene is an unknown quantity at this point
Help on the vacuum system
Does anyone know how to set up the vacuum cup/system? I can't find any instructions with the kit. I would highly appreciate any and all help.
Unread 17-01-2007, 08:52
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Help on the vacuum system
There are instructions, or at least a diagram, in the plastic package that the vacuum stuff came in. (I'm doing this from memory, so take it with a grain of salt.) In short, screw the metal connector into the suction cup, run a hose to the red knob side of the Venturi, run a hose out the other side (the one with the switch-looking thingie) to a valve in your pneumatics system.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 18-01-2007, 15:27
drewjones13's Avatar
drewjones13 drewjones13 is offline
drewjones13 is an unknown quantity at this point
Hello, we are trying to figure out how the suction cup is connected to our pnuematics system so I was possibly wondering if you could include an image of how to connect the suction cup to a basic pnuematic system. Thank you and happy building!!
Unread 18-01-2007, 15:34
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
This subject was continued on with this thread http://www.chiefdelphi.com/forums/sh...hlight=suction
I really like the vaccuum system, it's a neat little toy that they include in the KOP, but we'll probably use an active gripper for the game.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 25-01-2007, 14:25
Benyamene's Avatar
Team Role: Student
This thread was actually not continued because this thread is for possible scematics to the vacuum system. The thread Gabe listed is for possible ideas to which the vaccum could be hooked up for.
Unread 26-01-2007, 11:03
Andrew Morris's Avatar
Andrew Morris Andrew Morris is offline
Oh hey, it's build season!
FRC #0177 (Bobcat Robotics)
Team Role: Student
Andrew Morris will become famous soon enough
This diagram shows what the ports connect to. To use the one with the switch looking thing just push in the black ring around it(a standard quick release fitting) and pull out the plug(switch looking thing). Also, an easy way to reduce the tubing size(the vacuum system uses smaller tubing than the rest of the pnuematics) is to put a standard size quick release on the input side of a regulator and a smaller quick release(for the vacuum size tubing) in the output side since you should take the pressure down to 26psi for best performance anyway.
Unread 03-02-2007, 11:09
averagejoe_z averagejoe_z is offline
FRC #0939
averagejoe_z is an unknown quantity at this point
I am sorry but I still don't know where to go out the side with the switch looking things? Does anyone have a more specific diagram, does get hooked up to a spike, or what type of valve? I already have a pneumatic system on the robot with one pneumatic rod. How can I make the suction cup fit into my system.
Unread 03-02-2007, 11:20
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
The input from compressed air in the photo above goes to a solenoid. When the solinoid is energised the compressed air goes to the vacuum generator.
Hope this helps.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 03-02-2007, 16:53
FRC #0939
Call me stupid but I am still lost, what is the vacuum generator, is that the black peice in the KOP. Or do you have a diagram so I can picture it. Thanks for the help.
Unread 03-02-2007, 18:19
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
that is the piece in the KOP you have to use the thin green tubing that comes with it. Attach one end to the compressor, and the other to the suction cup, and then activate the compressor. it should generate a fairly strong vacuum. ours held a ring for 10 min before we got bored
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 04-02-2007, 21:03
FRC #0939
Thank you, that helps a lot. I was just so lost.
Does Max PSI Apply to the vacuum? sonofdad123 Pneumatics 8 17-01-2007 22:59
Absolute Positioning System Help Tom Bottiglieri Programming 5 05-02-2005 10:32
177's Vacuum System Peter Matteson Technical Discussion 5 18-11-2004 20:47
Help FSN Plan the System Jeff Waegelin Scouting 0 12-06-2003 12:49
Track System Help Needed archiver 2000 0 24-06-2002 00:15
