Re: pic: Team 1225's unfinished bot!
I'm always glad to catch a look at 1225's robot. (My mom's side of the family is from there; my cousin teaches math at East Henderson, and her husband is the football coach at Hendersonville High. 1293 also had a pretty awesome match with them at Palmetto last year.)
I've sort of been turned off by caster robots in the past, but they've been known to work wonders in the right hands. The one thing I might suggest is flipping the sprockets on the wheels around so they point inboard; doing so brings the sprocket on the BaneBots shaft closer in, which would cut down on side loads on that shaft. (The bearing block would also be a good idea, if you can fit it in, but the sprocket flip is free.) |
You sure have a lot of relays on there!
I think it's fair to assume that we should expect some crazy pneumaticness?
Crazy pneumatics? Yes!
Most of the electronics are for the pneumatics. We're going to try and build an articulated arm. Hmm Billfred, I took gym from B.J. Laughter last year. I think I remember you from competition at Palmetto last year. Nice to see you again. Team 1225 wishes you luck with your team. Thanks for the suggestion, it sounds like a good idea. We'll run it through the mechanical team. |
| Team 1225's Website | pheadxdll | Website Design/Showcase | 7 | 26-01-2007 15:13 |
| pic: 1726 Unfinished Parts | MrForbes | Extra Discussion | 6 | 26-01-2007 00:14 |
| pic: 179's Control Box (unfinished) | CD47-Bot | Extra Discussion | 14 | 11-03-2004 10:52 |
| Image Discuss: Maclay Robotics Team 654 - Unfinished | CD47-Bot | Robot Showcase | 3 | 26-04-2003 13:39 |
| Image Discuss: team 27's field, unfinished. | CD47-Bot | Extra Discussion | 4 | 13-02-2003 09:14 |
