Re: RS-545HS Gear and Pressure
Thanks thatll cover the pitch does anyone have any ideas on the pressure?
I think my post above was not very clear, because you seem to not have deduced what I meant....sorry for that!
I meant to take the mystery gear off the 545 mabuchi motor, and throw the gear away in the garbage. Then find a new gear that will fit the 3.2mm shaft, one that you know what the pressure angle and pitch are, and put it on the motor. |
Thanks
| KitBox Gear Info - What pressure angle? | coreyjon | Technical Discussion | 2 | 14-02-2005 22:01 |
| Translating pressure sensor readout into actual pressure | Mercutio | Pneumatics | 0 | 13-02-2004 16:29 |
| Dump valve and pressure gage's | tareyton | Pneumatics | 3 | 06-02-2003 21:13 |
| Gear Pressure Angle and Pitch. | Patrick Wang | Technical Discussion | 20 | 13-08-2002 20:33 |
| Error found in programming for the pump and pressure switch | sjharobotics | Programming | 4 | 06-02-2002 17:46 |
