Go to Post Who wouldn't love to see a circular FRC field, on the backs of four elephants, all riding on a gigantic turtle? - Taylor [more]
Unread 04-02-2007, 23:36
bjimster1's Avatar
bjimster1 bjimster1 is offline
AKA: Jimmy Bourne
FRC #1029 (Wolvcats)
bjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nice
Send a message via AIM to bjimster1
pic: team 1029 idlers and tensioners oooo aaaaa
Unread 04-02-2007, 23:39
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Re: pic: team 1029 idlers and tensioners oooo aaaaa
By the looks of it you have an automatic spring tensioner on your chain, but you may want to check the effects of driving in reverse, to the right in the photo on the tensioner, as the slack will be placed in the other side of the chain/ wheel connection, I don't know if you have thought of this yet, but you may want to try it before competition. If that is a locking type tensioner that isn't solely spring tensioned your ok.
but looking good guys/gals
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 04-02-2007, 23:54
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
Looks pretty.
Why do you have an idler on one side and a tensioner on the other--do they have different purposes? Also, what plastic is the tensioner made of?
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 04-02-2007, 23:59
redbarron's Avatar
redbarron redbarron is offline
Mike Barron
AKA: Mike
FRC #1270 (Red Dragons)
redbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to behold
1270 used those for I believe 2 years and they work nicely I never had a problem with them.
The Red Dragons
2005 Buckeye Regional Woodie Flowers Regional Award
2005 Florida Regional Finalist Along with 1251 and 845
2006 Palmetto Regional Engineering Inspiration Award
2007 Florida Regional Judges Award and Regional Winners Along With 1251 and 86
2007 Curie Division Winner with 330 and 910
2008 Florida Regional Team Spirit Award Winners
Unread 05-02-2007, 00:27
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Originally Posted by worldbringer View Post
Looks pretty.
I was wondering the same thing... It appears that both chains are going to wheels; so wouldn't it make it easier to manufacture spares if only one mechanism were used?
Unread 05-02-2007, 01:39
Mike o.'s Avatar
Mike o. Mike o. is offline
AKA: Mike O'Brien
FRC #1086 (Blue Cheese)
Mike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud ofMike o. has much to be proud of
Send a message via AIM to Mike o. Send a message via Yahoo to Mike o.
If I am looking at the picture correctly, and correct me if I am wrong. There are two chains, each coming off of the main drive shaft and going to two different wheels. Also if you look closely, the idler and tensioner are both on the same bracket. From this, I would assume that the bracket is either slightly adjustable or secured. I would assume that is slightly adjustable so that when the chains were cut for each wheel, that the idler on the left could be put into place so that is tensions the one chain run. Then the Spring Loaded tension could tension the other chain run, without having to be moved from its spot, it uses the spring forced to tension it. But that is just what I get out of the picture and the knowledge that I have gained from my engineering classes.
Needless to say, I love it, and have been trying to engineer/manufacture a design for the team that i was a part of to use in their drive systems. Really neat, and would love to see it in action.
Mike
Mike O'Brien
Founder, Almuni, & Mentor Team 1086
2010 GAL Division Finalist & Coopertition Award; NC Regional Winner & Quality Award; VA Regional Winner & Engineering Inspiration Award Winner
2009 CMP Team Spirit Award; VA Regional Winner & Chairman's Award
2008 VA Regional Winner & Chairman's Award
2007 & 2006 VA Delphi "Driving Tomorrow's Technology" Award
2005 VA Team Spirit Award; 2004 VA Imagery Award; 2003 Rookie Year
Unread 05-02-2007, 11:34
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The green tensioner looks suspiciously like a McMaster-Carr 7332K9 or 7332K11.
I guess I should get a paper version of their catalog....this online stuff is hard to find if you don't know what to look for!
Unread 05-02-2007, 17:26
Caleb A. Caleb A. is offline
FRC #0932 (Circuit Chargers)
Caleb A. is an unknown quantity at this point
It appears that you have 4 wheel drive with all 4 wheels being traction wheels, you may want to run that on carpet and try to turn around. In my experience we have always had problems with the robot "walking" since tank drive requires low traction to turn. Other than that your setup looks sweet! i like the color of the tread on your wheels i wish we could have found that before we put ours together.
Unread 05-02-2007, 17:30
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
They have a 6wd...
Unread 05-02-2007, 23:43
bjimster1's Avatar
AKA: Jimmy Bourne
First off, thanks for all of your input.
Justin, no problems here since the tensioner/idler takes out all the slack so there is no slack regardless the direction the wheels spin.
Looks pretty.
Mike
worldbringer and Cody, Mike is right, the idler and the tensioner are both mounted on the same bracket, one is spring-loaded the other is not. Mike, you pretty much nailed it perfectly. Also to Cody, you don't need spares if the engineering is done right!
Squirrel, thats because it is! Though I don't remember how much tension force they are, I think its the weaker one.
wrong to some extent...
Originally Posted by Arefin Bari View Post
They have a 6wd...
wrong. Arefin spreading lies, tsk, tsk.
Anywho, Caleb, you got the first part, we are using a 4 wheel drive or 4 x 6 to be exact. This is a tried and true setup for us, we used it last year. It is true this can be problematic for the reasons you described unless you know what you are doing and can account for it accordingly.
You can ask anyone who saw us at the Florida Regional or anywhere else that our bot had absolutely no problems turning, we were able to spin with the point of rotation being nearly perfectly in the middle of the robot!
Thanks for your thoughts and concerns anyways.
-2006 UCF Quarterfinalists w/ 1345 & 21
-2005 Peachtree Quarterfinalists w/ 1180 & 462
-2005 UCF Quarterfinalists w/ 1694 & 348
CMU '11
Unread 06-02-2007, 01:02
I was under the impression it was 4x4 drive. That has been the most problematic setup for our team because the rotation is centered between the wheels instead of on a center wheel in a 4x6 setup (we ended up switching the front wheels to Omni-wheels to resolve chattering. Glad to see you know what you are doing and best of luck to you thru the rest of the competition!
"If you're not FIRST, you're last."
Unread 07-02-2007, 23:41
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
Wait, does that mean that you don't Keep a spare tire in your trunk?
Unread 07-02-2007, 23:45
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
Nice treads we got them also, I like them a lot. They seem like they won't strip very fast. Other than that, nice setup!
Unread 09-02-2007, 13:05
Dick Linn's Avatar
no team (Synergy)
Looks almost like you could take a link out of each chain to reduce the angles involved. When we have the gearbox centrally located between the drive wheels, we make the chains as short as possible. Then we use washers under the transmission mounting plate to raise the tranny to remove slack. It is amazing how little is required if the chains are short, perhaps one or two washers will suffice, as there is little chain wear or stretch (we use #35 chain). Any sort of shim material will work, and it only takes a couple of minutes to loosen the mounting bolts a bit and slide in more shims.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 09-02-2007, 15:33
FDA1029's Avatar
FDA1029 FDA1029 is offline
cool guy
FDA1029 is an unknown quantity at this point
it would be great to have spares if we had the money, so were hoping that we engineered everything right to get us through the regionals.
Team 1029 urges you to Geek Responsibly (TM)
pic: team 1029 end of week 4... bjimster1 Extra Discussion 7 04-02-2007 00:24
pic: team 1029 teaser bjimster1 Extra Discussion 6 25-01-2007 11:13
pic: team 1029 shifter bjimster1 Robot Showcase 4 21-02-2006 10:23
pic: team 1029 bjimster1 Robot Showcase 9 20-02-2006 19:07
pic: team 1029 bjimster1 Robot Showcase 4 18-02-2006 20:55
