Go to Post Never should an idea be ridiculed, because ideas are exactly that just an idea. - Tim Delles [more]
Unread 05-02-2007, 07:59
Robostang 548's Avatar
Robostang 548 Robostang 548 is offline
I can program the future...
AKA: Don
FRC #0548 (Robostangs)
Robostang 548 is on a distinguished road
Send a message via AIM to Robostang 548 Send a message via MSN to Robostang 548 Send a message via Yahoo to Robostang 548
Question Magnetic Fields?
On our bot for this year our primary drive motors are located extremely close to or electronics platform. One of the drive motors is parallel to our RC and about an inch away. It is also located about two inches above all of the victors. Should I be concerned about magnetic fields from the CIM motors potential affecting or robot's performance or even harming the RC. Also, we have our pwm cables running alongside and perpendicular to our power cables. Should we be worried about the fields made by these wires affecting the signals in the pwm cables?
Unread 05-02-2007, 08:04
Re: Magnetic Fields?
Don,
Magnetic fields will have very little effect since they are not moving. The fields are stationary. The brush noise from the motors may prove to be a problem but only time will tell. Try routing the motor leads away from your RC and PWM cables or at least at right angles to the other wiring to mimize crosstalk. If you are having problems that can't be explained by anything else, it could be the brush noise. Brush noise is a high energy RF emission that is generated by the motor brush leaving a commutator segment. In the open motors like the FP you can see the sparks as the motor runs, which are the source of the noise.
Unread 05-02-2007, 08:42
MattLi's Avatar
MattLi MattLi is offline
Scrawny Asian Kid
FRC #0245 (Adambots)
MattLi has a spectacular aura aboutMattLi has a spectacular aura about
If you do have any more problems I highly doubt it is from magnetic fields. Check your programming to se if you have bugs. Try to change a battery. If you have a magnetic field around your robot parts then you have a lot more than a malfuntioning robot to worry about.
Per Ardua ad Astra-Through adversity to the stars.
~Royal Air Force
Magnetic Sensor on Pistons(help) DPPT1717 Pneumatics 10 12-01-2007 12:00
Magnetic Reed Switches (need help) cdennisxlx2 Pneumatics 1 03-02-2006 06:47
Magnetic Flux Keith Chester Math and Science 3 11-04-2005 09:35
magnetic sensor Justin_302 Electrical 5 22-02-2005 13:32
Do the CIM motors emit a magnetic field? JulieB Motors 17 27-01-2005 12:59
